I have distortion coming out is both speakers. Is it the processor?
How can I improve distorted sound on my Sony KDL32 EX403 television set.
distorted sound can be the speakers itself, it can also be the main processor for audio, if you have tried to change the sound settings and this does not help i would think its the speakers as some times they become damaged and split away from the magnet.
Nov 28, 2017 | Sony Computers & Internet
Internal Speaker not working properly suddenly. Hearing Ruptures along the voice.
If you have been using your computer with the audio on full you will probably have blown the speaker cones. An easy fix. Add some external speakers.
May 21, 2013 | Dell Inspiron N5010 Black
Diostortion, tinny , on one speaker, Dell Hi Perfomance, connected to base box. circa 2007, amd sempron processor, 3400+1.80 ghz
If it's distorted and tinny, the speaker is probably blown out, if the other speaker is working fine then the computer is not at fault!
So, you can either get new speakers, or a replacement component for that speaker.
Mar 17, 2011 | Dell A215 Computer Speakers
One of mine is distorting can it be fixed or can i just buy one speaker replacement?
I would rather advice you to look for a qualified technician to check where the distortion come from because it is not always come from the speaker alone.
Dec 26, 2010 | Wharfedale Crystal 40 Main / Stereo...
Right channel is having distortion even if the voulme is turned off. I tried swapping the speakers and cables but still the distortion can be heard from the speaker. It is still coming even if the jumper...
you need to check for the filter capacitor on that channel, and going to the power amplifier. some distortion come from leak parts and need to trace that manually.
Apr 13, 2010 | NAD C325BEE Amplifier
Putting Speakers in Door Dont Know how to wire them correctly
Wiring speakers with reverse polarity doesnt have adverse effects. It cant give distorted sound. Seems like the wiring from the head unit to the speaker might be at fault. For testing purposes, connect the speaker directly to the head unit, bypassing, the car wiring. If the sound comes out alright, you have to replace the car wiring. If it is still distorted, speaker might be at fault. Try with a different speaker.
Oct 20, 2009 | Pioneer TS-G1642R Car Speaker
Playback distortion
Good day sir, distortion can be caused by several factors, 1. overdriven audio source, try tuning down the volume to half. 2. the speakers are defective due to driver's coil scratching the magnet. need to replace the speakers, better swap first any good known speakers. hope this may help. if you may have any more questions, feel free to ask again. thanks
Jul 18, 2009 | EMC Zotac GF6100-C-E MCP61P GeForce 6100...
Your speakers are worn if you can try someone else speakers. Speakers tend to wear out with excessive use particularly when played once or twice loud its a try that wont hurt at least for peace of mind you may need not throw them out.
Sep 28, 2007 | Boston Acoustics MediaTheater Computer...
Using dvd drive makes makes sounds
There is nothing wrong with your laptop. If you are copying a cd and trying to play music at the same time, you are pushing the processor power of your laptop or low on memory. When copying a cd it should rip it without sound to your hardrive, so i assume that your are playing music from your hardrive as well as ripping and this model of laptop i think comes standard with a 1.3ghz processor with 512mb of memory, which can easily be drained when ripping or burning.
Mar 03, 2007 | Acer TravelMate 2300 Notebook
