Question about Minolta DiALTA Di520 Laser Printer
C 0924 When i turn It appear message c 0924
C.0924
Posted on Oct 24, 2010
  • Minolta Master
  • 1,294 Answers
Paper misfeed in rear side to paper tray,blocking the paper actuator or sensors.
Posted on Jul 30, 2009
What must be done to remove a C0914 code from a minolta 5000?
Turn off the machine. Wait 15 second turn on the machine. Once you get to the ready to copy screen. Look at the lower left of the screen you will see a small wrench icon. I want you to touch it, the copier will go to another screen. When it does I want you to open close the front door. That will reset the codes, If it comes back then you have a problem with a draw.
C-0914 is the second draw lift motor. So first remove paper. if the code clears after that add some paper. Does it do OK? Might have a bad lift motor.
C-0924 1st draw lift motor do the same.
Mar 10, 2015 | Konica Minolta Office Equipment & Supplies
How do I turn the voice command off on text messages
To turn of this setting:
1. From the home screen, press the Voice Commands key on the right side of the phone. The Voice Commands screen appears in the display. 2. Press the right soft key Settings.The following options appear in the display:
• TXT Msg Readout: Reads out the text in a TXT message. (Turn this off)
Jan 04, 2015 | Samsung SCH-U450 Cell Phone
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
Aug 12, 2012 | Canon Cameras
I need a Toshiba tv code for a ge universal remote # jc022
Try these codes.
012, 013, 049, 071, 072, 089, 095, 105, 109, 117, 118, 120, 141, 159, 160, 162, 170, 178, 181, 260, 358, 394, 902
0159 0178 0109 0120 0181
0105 0049 0095 0170 0260 0358
0394 0924 0012 0095 0117 0141
Mar 18, 2012 | GE Televison & Video
When i turn it on i get error message C-0924.
Usually this code pertains to paper stuck to one of the drive motors one of the the paper trays. The trays are easily to remove there is bracket on the right side on the main body of the machine.1 screw bracket stopper plate.
Sep 10, 2010 | Konica Minolta DiALTA Di200 Copier
The reciver is stuck in demo mode. Can`t get it out of demo mode.
The demonstration will activate the first time you turn on
the power. When the demonstration starts, the following
message appears in the display:
“NOW DEMONSTRATION MODE IF YOU FINISH DEMONSTRATION PLEASE PRESS POWER KEY WHILE THIS MESSAGE APPEARS IN THE DISPLAY THANK YOU”
To cancel the demonstration
Press the Power 1/0 button to turn the receiver off while the above message is being displayed. The next time you turn the receiver on, the demonstration will not appear.
It's in the manual - page 3.
Jun 10, 2010 | Sony STR-DE445 Receiver
When i turn my laptop the message appears saying
I recommend getting it reformatted to be honest goto a pc store it won't be much :)
Dec 14, 2009 | Toshiba Satellite A60 Notebook
Message turn power off and on again
your lens may be jamed thats why it tells you to turn off then on its tring to cycle the lens so i would check that first! good luck!
Sep 02, 2009 | Sony Cyber-shot DSC-M2 Digital Camera
Start Error Message when turn the key. No clicking, Dash normal.
seems like your key is not being recognized, possible your tumbler..the ring around your ignition switch is bad
Jul 05, 2009 | 1999 Mercedes-Benz M-Class
Lens error
Hey Wiggs12485,
This error message appears when the camera detects a problem with the lens when it's turned on. This is often caused by the user pressing on the lens when it is trying to extend, or the camera is being used in a dusty or sandy environment. When this message appears turn the camera off and back on, and this should resolve your issue. If this message continues to appear you should have the camera looked at by an authorized service technician because there is probably a problem with the lens.
Sincerely,
Allan
Go Ahead. Use Us.
May 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
117 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
