SOURCE: how do you un clog a whirlpoo cabrio washer
Clogs in a Cabrio commonly occur when the drain pump becomes obstructed. The following link explains step-by-step how to access the pump(s) and clean them out:
http://www.fixya.com/support/r4155097-checking_drain_pump_whirlpool_cabrio
The Cabrio is unique in that it has two pumps and a fairly large tub capacity compared to most washers. If the wash tub has any standing water, make sure you drain it from the tub prior to removing any drain hoses. Otherwise, you will have a potentially large mess to clean up. Using a wet/dry shop vac to pull a vacuum on the drain line is an effective and easy way to drain the tub.
If you have any questions about any of the these procedures, please post back and let me know. I hope this helps you.
SOURCE: I have a top loading
Here is a complete service manual for your washer. Look at page 6-4 for putting your machine into diagnostic mode to retrieve any fault codes that may be stored and post me the results.
