Does this model Washer and dryer bundle) has any recalls DV42H5200EW 7.5
2 Suggested Answers
  • 6 Answers
SOURCE: Samsung dryer model number dv42h5200ew/a3 wont start just a click sound
There is a thermal overload located on the dryer heater housing. You have to remove the front panel to get to it... little bit of a job, but is doable if you google it.
Posted on Mar 28, 2017
Mar 28, 2017 | Samsung Dryers
Has there been a recall on the Kenmore H3 washer or dryer?
any recall issue will be available on the website for the machine i.e. www.kenmore.com or on the consumer reports website. From this listing I cannot see a recall for this particular machine
Aug 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How to un-stack Bosh Washer WFL 2060/Dryer WTL 5410
Did you ever get an answer? I have the same problem...
Mar 21, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Maytag washer filled with water then stopped working.
check your belts there are two of them one for the pump and the other the transmission
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Cracked Drum on LG Dryer Model #DLE2512W
I had a 2514 with a similar problem. Cracked drum. This is what I did to fix it. With the new drum. No noise at all.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Feb 10, 2009 | LG DLE2515S Gas Dryer
Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Aug 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore elite oasis washer
I too had the misfortune of dealing with the continuous beeping on my washer (model # 110.27062600). No code was given.I called the Sears hotline and asked for the manufacturers warranty department. I then called the recall line at (800)659-7026 and after giving my model number and serial number they discovered is was indeed recalled or being "upgraded"! They have ordered the part and are sending someone out. For those who have already paid to have it repaired I would call Sears and ask for a refund. Good luck!
Jan 06, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
