My 4th channel on my akai gx 400d ss is not working. Lights up.
  • Audio Player... Master
  • 1,267 Answers
Clean the heads real well then after that it is a matter for the Technician to work on.
Monster mpa 5150 ss amp
the unit is not able to tune above that channel .
means its a failure of components in the control board.
Jun 29, 2008 | Monster Cable MPA 5150 SS Amplifier
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
How to connect a GX-280D-SS to amplifier
Line outs to tape in or Aux in that is all that is too it.
Feb 18, 2014 | Audio Players & Recorders
Akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
Aug 26, 2009 | Audio Players & Recorders
As It was mentioned on the premium post, if after removing the fuse(s) from it, the amp powers up and stays ON; the failure is on the transistors or mosfets and they will need to be replace to get the amp working again on channel 4.
I would suggest to contact the manufacturers to get an authorized repair center to fix it under warranty if your amp is less then a year old.
Good Luck.
Jun 30, 2008 | Monster Cable MPA 5150 SS Amplifier
4th channel turns on and then it turns off; 5th channel does not turn on
Hi Alex323a
Nice amps. There is really only one check you can do without getting into the internals of the amp to help you resolve the issue. Disconnect the input and speakers from that channel,and see if it is able to turn on. If are up to it, checking over the poweramp board for that channel for dry or cracked solder joints, and in turn resoldering any you find may fix the problem. If not, the amp will have a problem on that channel and will need a tech to look at it. If it is under warranty still, Monster are pretty good for service I have heard, and they would be your first port of call. Other than that, Call you local HiFi specialist store and see if they can recommend a good audio tech in your area.
Jun 28, 2008 | Monster Cable MPA 5150 SS Amplifier
Unable to record with Akai GX-77
Make sure the cassett you are using has safety tab intact. Clean the heads and tape drive roller. If unit has a record level control, make sure it is set correctly
Apr 07, 2008 | Audio Players & Recorders
