Question about Cell Phones
Landvo v81 phone frozen on startup. will not factory reset
Factory reset for galaxy tab
Method 1: From Startup (Tab 4)
  1. With the device off, press and hold the "Volume Up", "Home", and "Power" buttons.
  2. Release the buttons when you see the recovery screen and the Samsung logo.
  3. Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...
  4. On the next screen, press "Volume Up" to continue.
Jul 15, 2016 | Samsung Galaxy Tab Tablet PC
Screen is frozen on startup. is there anything i can do to reset it
Try Power Flee.
Turn off the Laptop by pressing the power button.
Take out the Battery and Power cable and press the power button for 30sec.
Then connect the battery and try to boot it again.
Oct 03, 2014 | Computers & Internet
How do i do a factory reset if my phone is frozen?
What phone do you have? You need to give more info
Aug 13, 2014 | Blu Advance 4.0 A270a Cell Phone
Phone locked up
To Restore to factory settings
1. From the application menu, Select Settings
2. select SD Card & Phone Storage
3. Select Factory data reset
4. Select Reset phone
5. Enter your password if required, then Select Yes to confirm
To do Hard reset if your phone is frozen:
1. Turn the power off. If your Samsung Moment is frozen, pull the battery out and put it back again
2. Hold the Volume Down button, Call and End until "Samsung" appears on the screen along with a menu
3. Select Master reset device
4. When the phone is done erasing, choose the option to reboot
Once the Samsung Moment reboot it returns back to factory-fresh default state settings.
Feb 21, 2014 | Samsung Galaxy Reverb SPH-M950 Virgin...
How do I reset LG P500
Factory Reset on Menu Setting
1. From the main home screen, tap menu
2. Select Settings, then Privacy
5. Enter the password if required, then confirm by selecting Erase everything
Hope this helps,
If the phone is frozen, hard reset it through buttons
1. Turn the power off. If the phone is frozen, pull the battery out and inplace it back again
2. Hold the Home and Volume Down button
3. Press and hold the Power button until the phone turns on
4. Follow the on-screen instructions to hard reset the phone handset
The LG Optimus One P500 will then reboot to its factory fresh default state settings.
Sep 19, 2011 | LG P500 Cell Phone
How do I reset my lg optimus
See the instructions below how to factory reset your LG Optimus
First, try this:
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your LG Optimus T is frozen, pull the battery out and reinsert it
  3. Press and hold the Power button until the device turns on
  4. Follow the on-screen instructions to reset your device
All data including third-party applications will be deleted from the LG Optimus T. Once the wipe is complete, the phone will reboot to its factory fresh state.
Amardeep
For More Tips, Visit My Blog @ http://thegeektweet.wordpress.com
May 27, 2011 | LG Cell Phones
Master reset
Factory Reset procedure: this can only be done if your phone is not FROZEN.
1. From the main home screen, select Menu
3. Select Factory Data Reset
4. Select Reset Phone
5. Enter your password, then select Yes to confirm
Hard Reset Procedure:
1. Turn the device power off. If your phone is frozen, pull the battery out and reinsert it back
3. Press and then release the Power button
4. A menu will appear that allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Just Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button again
7. Select one of the option then confirm: Volume Up for YES and Volume Down for NO
Once the wipe is complete,Your Samsung Vibrant will reboot to its factory default state settings.
All your data including third party applications on your phone already deleted, you need to reinstall it all back again.
Sincerely,
Eury Satorre
May 13, 2011 | Samsung Cell Phones
I want to reset a HTC HD7 but i dont know how. can you help me?
1. From the Start screen, tap wp7arrow.png in the upper-right corner.
2. Tap Settings.
wp7settings.png3. Scroll down and select About.
wp7about.png4.Tap the Reset your phone button.
windows-phone-7-reset-button.png5. Confirm your selection by selecting Yes. Then tap Yes again.
Your HTC HD7 will then go through the process of resetting to factory default settings.
Option 2 - Resetting using the hardware buttons
You can also use the buttons to perform a hard reset. This comes in handy if the screen is frozen and you can't access the phone.
1. Turn the phone off. If it's frozen or unresponsive, pull then replace the battery.
2. Press and hold the Volume Up and Volume Down buttons and power the phone back on.
3. Continue to hold Volume Up and Volume Down until a factory reset screen appears.
Mar 08, 2011 | HTC Cell Phones
Frozen
Take it out of the freezer.
ba..ba...BUM!
No, seriously, have you tried to reset it? Is your battery good?
Did you drop the phone on the ground or into water? If no dice after the reset, take it to a phone dealer who might help you.
Jun 01, 2008 | LG CU500 Cellular Phone
Cell Phones Logo
53 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
