Question about Lands Phones
Have presidan dect 6.0 will not work second hand set main unit sas it is unit 2
  • 1,272 Answers
Hi, the issue is not clear.
Please be more specific.
Posted on Jul 21, 2009
  • Anand Gupta
    Anand Gupta Jul 28, 2009
    Has the issue resolved? If not, then please let me know so that we can work for a solution!
    Regards
    Anand
  • Anand Gupta
    Regards
    Anand
Airbad error code 47
For a 99 626, the service information says that code '7' is for the passenger side airbag module. I know that your question says that you have a code '47', but the information has codes 1 / 2 / 3 / 6 / 7 / 11 / 12. It states "replace SAS module for codes not listed." The SAS module is the main airbag computer.
Jan 12, 2014 | 1999 Mazda 626
Our DECT 6.0 4 phone system has been working fine for well over 1 year. All of the sudden when you dial out and the person on the other end answers they can't hear you. If someone calls here you can hear...
Sit the headset units back to the main base one by one.
Make sure you do all of them at the sametime.
This will reset the DECT 6 security feature.
Swap out the rechargeable battery to rule out weak battery problem.
Oct 22, 2013 | AT&T DECT 6.0 Cordless Phone System with...
I get a message hand-set not in range. No charge light. Hook up appears OK. Second home phone works properly. Prior to problem I tried to dial a local no. but entered 8 nos. Phone says searching or...
Dialing the 8 numbers should not cause a problem.I have a few suggestions,you may have tried a couple already.Hang up the problem phone on the base unit for about 30 seconds.If that does not help,remove the battery for a few seconds and try the 30 second hang up again.Try unplugging the base unit for a half minute.I am trying to get it to reset itself and link to the base.Is the second phone part of this system too?We had a Uniden and I personally thought it ended up being garbage and will probably never buy another one.If you end up deciding to buy a new phone,the new technology is DECT 6.0 and is supposed to have better range from the base,clearer sound to name a few things.The strange thing about it is that it operates at 1.9 GHz.Also,if you decide on a new one,google DECT phones.There are all kinds of forums about peoples opinions/ratings of ones they have bought and used for a period of time.If you have any questions,just comment on this post and I will get an auto email saying you posted.Good luck! Greg
Aug 14, 2010 | Uniden Lands Phones
Searching and out of range message keep appearing. Can't dial out or receive calls Uniden Dect 6.0 (both phones) Tried to register base but unsuccessful.
This is because of the following reasons
1.The handset is far away from the base unit.Try to bring the hand set near the base unit and try.
2.The base unit is not plugged in to the power supply.Please check it.
Thanx
Jul 27, 2010 | Uniden DECT 6.0 Cordless Telephone...
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
d65e3ff.jpgon the base unit until 608a95f.jpgstarts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
19efd34.jpg together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
Jul 22, 2010 | Doro DECT 540 Cordless Phone
Ge model 28213ee2-a 2nd handset doesnt ring when a call comes in
assuming all the settings are correct, and sometimes there's a tiny switch on the handset for ringer, that has to be on, try the 'page' feature [the button on the base to make the handset ring to find it] - if that doesn't work, there's a very good chance the ringer itself is bad. i've seen that many times.
May 26, 2009 | Uniden Cordless Phone
One handset doesnt ring
There should be a ringer tone and volume control on the second handset. Sometimes there is a ringer on/off switch on the side of the handset.
If that doesn't work, then there is a possibility that the speaker is broken.
Rolex ad Daytona 1992 replica
The advice given here is accurate to a degree. When wound, a rolex daytona IS running. However, it is the running seconds hand in the small sub-dial that is actually running. In the earlier Daytonas, this sub-dial was at the 9 o'clock position on the dial, (pre-2001 series daytonas). The later daytonas, from 2001 on, use the seconds at 6 position for counting seconds. The main sweeping second hand on the watch dial will NOT start until activated by the pusher at the 2 position. That pusher needs to be unscrewed and then pushed to start the large sweeping second hand. This action, in turn, starts the remaining 2 sub-dials in motion, counting minutes and hours. To stop the chronograph function, you push the pusher @ the 2 position again, to stop the sub-dial hands from counting, and then push the pusher @ the 4 position to re-set the dials to their "straight up position". This stops the chrono's function, until it is needed again, BUT the main running seconds, (at either the 9 or 6 sub-dial position, depending on the year series of the daytona) will continue to run, thus keeping accurate time.  Hope this gives you a better idea of how the timekeeping of the chronograph function on a Daytona works. So, to start your seconds running you need to start the chrono function by pressing the pusher at the 2 position. That will allow you to see the large sweeping second hand I think you're referring to here. Hope this has helped.
Doug
Jan 11, 2008 | Rolex Daytona 116520 Wrist Watch
Lands Phones Logo
23 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
