Question about Ricoh Office Equipment & Supplies
My ricoh copier machine 2530 print give me a copy the toner not pasted very well on the paper it is look like robe on the paper what the problem .pls?
  • 86 Answers
SOURCE: Toshiba 2860 Plain paper copier
It maybe the waste toner container is full try emptying it
Posted on Feb 19, 2008
SOURCE: Konica 1216 copier makes black dark copies
dear sir i have information P 27 on my konica copier. how do i solve the problem..?
Posted on Sep 07, 2009
SOURCE: Paper Jam Remove Toner message with constant
In the front (inside body) see the sensing feeler ( a piece conected to a microswitch) is free to move.
Sometimes when pull the paper with some force, the sensor become forced in their base.
Verifie if the sensor is moviming free..
Posted on Nov 20, 2009
  • 74 Answers
SOURCE: Ricoh 2045 Doesn't recognize new toner cartridge
This is probably one of two things, first it could be is that the stopper out of the old bottle has got stuck inside the Toner hopper and preventing the hopper from getting toner from the new bottle.
This would be caused by the second problem that is the hopper is more than likely clogged up and the jaws that grab the toner bottle cap cannot open, you can either clean the hopper out, it can be dismantled by removing the silver pin on the green handle, but do be care full as when this pin is removed you will fire the internals out accross the room, so have your hand in front to cach them, then just clean it out reassemble and you should be fine.
Just remember always try the simple fix with copiers, so many engineers look way to far into problems whenit's staring them in the face, i am a Technical Specialist with Ricoh Masters and find a lot of basic faults are overlooked
Posted on Dec 09, 2009
  • 44 Answers
SOURCE: Ricoh copy machine 3025 paper jams every time we try to print
If the sheet of paper is damaged there may be a blockage in the paper path. If the path is cleared and it still damages the paper then the feed rollers could be worn. Question for you, when the paper gets damaged does it fan up like an accordian? if so there is an issue in the fuser section. Hop this helps
Posted on Sep 30, 2011
Problem with printing, no ink on paper
The print heads are clogged or you are out of ink. Try the steps in the link (Epson support page).
Epson WorkForce WF 2530 All in One Printer
Apr 06, 2016 | Epson WorkForce WF-2530 All-in-One...
Double image on ricoh mpc 2800
Make sure that the printer is set properly for the weight of the paper. If it is 28 pound laser color paper, set it up for middle thick, etc., in (User Tools / System Settings / Tray Paper Settings). It will run the machine slower, so the toner will more fully melt and adhere to your paper.
Jan 28, 2015 | Ricoh Aficio Mpc2800 Digital Color Copy...
Ricoh aficio 2045e
try to shake the toner cartridge and reinsert it in the printer, if still getting the blank paper, try to print a stand alone test page or if its a multifunction printer try to make a copy and check if its printing or not
reply
Dec 07, 2013 | Office Equipment & Supplies
I get dirty background copies despite having cleaned the photocopier a month ago. When the toner bottle is placed, there is toner everywhere within the compartment when the machine is used. Unable to fix...
looke my friend try to go in sp mode and make free run printer via 5802 and ok and press copy sp and back to copier process and print 100 shett don't worry it's not print paper already
Jan 15, 2011 | Ricoh Aficio 1035 Copier
You can smear the print by touching it on the copies you make. The toner is not being fixed to the paper.
please check your fuser/fixing unit if it is ok or heating & pls specify your copier model ei" RICOH FT ____ RICOH AFICIO ____
Nov 24, 2010 | Savin Office Equipment & Supplies
Paper Jam Remove Toner message with constant beeping. Removed toner cartridge and checked for jam but none found. Tried with new cartridge but same result. One time, the machine started its heating and...
Nov 13, 2009 | Ricoh Aficio 1022 All-In-One Laser Printer
How many copies should a copier produce before changing a drum
I bought a km1620 copier. but copied only A4 size paper. No longer paper can not print except A4 paper. how can I change copying system. And how can I count copy. pls. mail me.
mizan
Jun 12, 2009 | Kyocera Copystar CS-1620 Black and White...
Ricoh aficio 3025 copies out of alignment
Check the paper size dials (green dials) of the paper trays that are set to match the orientation of the paper loaded in the tray.
On the touch panel display, select Auto paper select icon and retry.
If the dials are correct and the problem still there, please then try to print the counter printout from the User tools (yellow) button or send a print from your computer.
If still with the copies being cut off, please check for toner spillage between the toner unit and Photoconductor unit.
Open the front cover, pull out these units and clean toner spill.
Clean also the laser shield glass. There is a small cover below the toner supply unit, unscrew 1 screw. Pull out the small glass very careful and straight ahead, pay attention not to break it.
Retry copying and printing.
Good luck and please rate me, thanks.
Jan 21, 2009 | Ricoh Aficio 3025P Black and White Copier
Ricoh ft3713 toner overflow
remove the toner bottle, open the back cover and look for the small DIP Switch turn on and off, by doing this you are forcing the machine to come out from add toner condition. Then you do 20 sky shoot.
Oct 24, 2008 | Ricoh FT3713 Copier
Light and broken printout and black mark on the backside
Have the service people set the machine to add toner(per pixelcount) and test run it for a day or two. If this works it means the sensor in the developer unit that tells the machine to add toner from the cartridge is bad. If that is the case replace the sensor. It sounds like the machine is not adding toner to itself. Have them also test the toner motor.
Aug 24, 2007 | Ricoh Aficio 2015 Copier
22 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
