Question about Neff Dishwashers
Neff dishwasher has flashing lights and wont runn
S9J1F
3 Suggested Answers
SOURCE: Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Posted on Aug 26, 2009
BElectric
  • 1140 Answers
SOURCE: neff s9j1f everything working fine
The most common reason for a dishwasher running but not heating is because the heating element/coil is open-circuit, i.e. burned out.
It could also be a control module fault so some testing would be done to determine the fault. You can do this yourself if you have a multi-meter / ohm-meter and can get access to the element. If the element is working you will get a resistance reading of between 25-30 ohms if the element is working. If this checks out, then you probably have a control module fault and in most cases, these need to be replaced unless you know someone who can repair PCBs at component level.
Both element and control module can be replaced by a reasonably competent DIY'er as long as you have some basic instructions for disassembling the washer and can get the part. Replacing the control module will be significantly more expensive than replacing the element. An enginner would charge between £70-100 to replace the element and £130-£180 to replace the control module. If you're quoted more than this, find someone else!
Hope this helps.
BElectric
Posted on Nov 05, 2010
How to fix neff dishwasher
Sounds like you have water in the base of the appliance caused by a leak, which in turn has activated the anti flooding device. OR the control module is faulty.
Remove appliance from housing and remove water from base, check for leaks.
OR
Replaced control module
Aug 23, 2014 | Neff 24 in. S5409X0 Built-in Dishwasher
Neff dishwasher - bottom tray not cleaning - rotary arm not turning
If your dishwasher is 10 years old and you are facing a significant repair cost, it may be time to consider replacement.
Jan 01, 2014 | Neff Dishwashers
S5453x1gb/50 s9j1f integrated diswasher door does not close
if the door is not closing do you mean will not stay closed this may be because of the locking hasp or the handle/lock located on the door on the top of the unit if the door is not moving up and down then this would because of the lower pulleys inspect your machine further and message me back with your finds Thanks again Rick
Jan 08, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
My neff dishwasher is not filling with water
Hello
Water inlet valve is responsible for filling water in your dishwasher, when that goes bad either the dishwasher wont fill at all or will fill the water slowly. Please check the inlet screens and also try to clean the water lines for any clogs/obstructions. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Neff Dishwashers
Neff s9j1f everything working fine exept it wont heat the water at all, any ideas. thanks
Hope this helps.
BElectric
Nov 05, 2010 | Dishwashers
My neff dishwasher will not fill will water and will not complete program - cleaned and checked filters to the best of my knowledge - can you help?
i if it doesnt fill with water check it is actually draining is there water in the tub etc?if it cant drain it wont fill or complete the cycles,this is usually a blockage in the pump the handbook tells you how to deal with this problem.
Jul 29, 2009 | Neff 24 in. S5555X0GB Built-in Dishwasher
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Hotpoint sdw dishwasher
It is possible drain pump blocked, you need to empty d/washer manually, check inside drain pump which is at end of drain hose, always isolate d/washer from power before attempting any work on it.
Aug 14, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
