1996 Audi A6 Logo
Posted on Jul 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have no key and alarm keeps going off
Wife has key and wont give it back till divorce goes through. car on drive drivers door unlocked however alarm keeps going off how do i disconnect it
Anonymous
Level 2:
Sergeant:
  • Expert 273 Answers
  • Posted on Jul 21, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
273
Questions
Helped
108388
Points
878
If you disconnect the brown earth wire from the alarm hub it will disable the alarm
3answers
How to disable alarm in 1999 monterro sports
disconnect the battery...wait 30 mins and the pcm should reset.
Change the battery on a 2005 kia sedona key alarm
Try disconnecting the neg. battery terminal. Open the drivers door and leave it unlocked then reconnect the battery back up.
1helpful
Alarm won't shut off on 1999 Chevy blazer 4x4
Is it factory alarm or aftermarket??. Try using the key to lock and unlock the doors driver and passenger then turn the ingnition on with the key and leave it in the key on engine off position for a few minutes and start the vehicle
1helpful
Alarm wont go off
conect back the battery close all doors and windows driver door insert the key unlock the door one time and hold the key until window goes all way down then turn key to lock the door hold to lock position until windows go up if no stop repeat one more time right way without taking the key out , hope this help.
1helpful
Wont go off
Try unlocking from the passenger door. Some of these had a key cylinder switch on the back of the lock cylinder which deactivates the alarm. If it works ok from passenger side then the switch inside driver door would need replaced
2answers
Lost keyless entry remote
The fuse for the alarm is under the hood. Give a good look and you should find it. Once you have pulled it it will deactivate the alarm I am not sure if this is exactly your problem since you said that the car wont start.... but it is worth a try.
6helpful
6answers
Jeep alarm will not turn off
The ignition security on/off is located at the trunk lock. unlock and lock rear gate and the alarm will turn off. My jeep sat in my drive for a month before a jeep tech told me this. It still triggers the security sometimes when I unlock the passenger door with the key and I go straight to the rear gate lock and it shuts off instantly.
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
