Question about Bissell Vacuums
Bissell 2x carpet cleaner do not spray water
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
  • 4 Answers
I have owned three Bissell cleaners and experienced clogged hoses each and every use. Do not put carpet cleaning solution in these machines. They are not designed correctly. If you have a tough spot, just use some liquid dishwasher detergent and a scrub brush. It will get almost anything out! Try it! Then, use the Bissell with hot water only to clean up any detergent residue.
Have a great day! Bissell Sucks!
Posted on Aug 31, 2010
heatman101
  • 43501 Answers
SOURCE: bissell proheat 2x carpet cleaner 9200 How do i
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
teyet
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel pro2 carpet cleaner stopped sraying how to fix
Hey Diane! Sorry you're having difficulty with the spray on your ProHeat 2X. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Bissell 2X Proheat 9200 rug cleaner
Water will not spray
heatman101
rt2
Aug 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet cleaner will not spray the cleaning solution
heatman101
hgjdg
Jul 21, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
32 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
