Question about Sharp Microwave Ovens
Replaced a blown fuse and it blew again - Sharp Microwave Ovens
  • Sharp Master
  • 9,085 Answers
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You or a friend should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
The fuse holder may be loose buy fatigue.
With the microwave unplugged, if you can easily turn the fuse with your thumb & forefinger while it's in the holder, it has overheated and fatigued and the holder should be replaced.
Simply squeezing the holder's terminals together with pliers is not solution. Metal fatigue is permanent.
When a connection is loose, heat results, which eventually melts the fuse internally.
This is usually evidenced by a very tiny ball of solder at the point where the end cap meets the body of the fuse.
You can use a generic holder - it's a lot cheaper than an OEM part.
The connectors should be 1/4" tabs and it should be rated at 20 amps or better.
You should be able to get one from a home center or local appliance parts store.
Feel free to e-mail me at pupista@gmail.com with your full model number as shown on the tag in or on the oven, and your detailed symptoms for free advice.
Posted on Dec 31, 2016
Blown Fuse on a Sharp Microwave
I answered your dupe post here:
http://www.fixya.com/support/t26419783-replaced_blown_fuse_blew_again
Dec 30, 2016 | Sharp Microwave Ovens
WHAT WILL MAKE MY GE MICROWAVE WES1384SM2SS FUSE KEEP BLOWING I REPLACED IT ONCE AND AS SOON AS I OPEN THE DOOR IT BLEW AGAIN
The fuse is there to protect your home in case something has gone wrong inside your microwave. Since the fuse has blown twice, you can safely assume that there is something wrong inside. It may be fixable, it may not be economic to fix it. Impossible to troubleshoot electronics without the unit and test equipment.
Jun 04, 2015 | GE Microwave Ovens
Fuse blown in the back of Euromaid oven, What can cause this??
Hard to say what blew the fuse, suggest you replace the fuse and if it blows again take it in for service
Jan 30, 2015 | In Microwave Ovens
Panasonic inverter microwave ct579 killing the 10a fuse. Uk.
Check its transformer so that you will know its fuse size
Sep 12, 2014 | Panasonic Microwave Ovens
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
Fuse was blown i replaced fuse then when i tried using oven it made a almost like grinding noise for about a half sec then blew fuse again tried unhooking turntable didnt help
Your Magnetron or High Voltage diode (or both) has failed.
Replace as required but IT HAS VERY DANGEROUS VOLTAGES INSIDE. PROCEED WITH CAUTION!
Nov 03, 2010 | Goldstar MV-1310W/B Microwave Oven
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Emerson Microwave Model MW8119SB found blown fuse. Replaced fuse power came back punched in 10 sec started microwave and fuse blew again.
Chances are that either the diode or capacitor are shorted. Be very careful, the capacitor can store a charge and should be discharged first for safety. Hope that helps...
Geno
Dec 06, 2009 | Emerson Microwave Ovens
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
