Question about Pool & Spa
How do i bleed my aqua-flo flo-master XP2 pump? It starts up in both speeds but moves NO water. I am thinking I have air in a line
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
Your pump will not prime with air in the line. Check the impeller for junk in it. Clear it out by opening the pump lid, and then opening the air bleeder on your filter. That will flush the stuff from the impeller. Check pump lid gasket, and make sure all your baskets(skimmer, and pump) are empty. Prime pump. That should get it flowing. Also, clean or backwash your filter.
Posted on Jan 21, 2017
Flow master XP2 by aquaflo for spa; it clicks, but does not start. I could turn the shaft with a wrench, all plugs work.
the start switch has trash in it , use compressed air and blow out the back of the motor, this works most of the time for me. otherwise the motor will need to be dissembled and can be tricky do to easy to break parts. search your area for your local pool pump motor repair guy with free testing. and ahve him clean the switch
Sep 14, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
I was told that the Aqua Flo Master Xp2 Spa pump 1.5 hp 2 speed pump was the equivalent to the Sta rite Max E Pro 2 speed pump but then from another source was told that the Aqua Flo was not made for in...
I responded to the previous question in regards to the motor only. The xp2 does not have the strainer basket that the max-e-pro has . If this was a regular hot tub, the xp2 would work great, if this is above ground, then you do need a pump with a strainer basket. Again the xp2 will not work for an inground hot tub as the set up is different than an above ground unit.
Jan 12, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
I am looking for a Flo-Master XP2 by Aqua Flo. Modal 06630397-2. How much would it be?
A quick google search brings up a number of online sites between $340, and $430
Sep 22, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pump shuts itself off
Fill the tub with water, disconnect the supply pipe to the pump and ithe head of water should push out any air
Make sure you can get the hose back on easily before you fill the tub other wise you are going to get wet
Oct 09, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Pool & Spa Logo
666 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
