Is it a 50Hz HDMI Mode on a flat screen tv on Polaroid? i do not have to change channels to us Chomecast?
SOURCE: DirecTV Remote Control of Polaroid TLA-01511C
These worked for me
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341, 11498, 11523, 11991, 11992
Posted on Dec 10, 2007
SOURCE: Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Posted on Mar 24, 2008
SOURCE: polaroid FLM-2601 power supply board
The part number is 6LM00220G0 and is priced at $80.54 at circuit city repair. It is easy to install once you remove the cover from the back of the TV and the housing for the power supply.
Posted on Apr 08, 2008
SOURCE: akai lct42z6tm
I can confirm that replacing these 4 capacitors worked perfectly. I work in construction so i am not a technician or anything. I did not even have a solder iron. I have photos of the board if anyone would like to see them. Took me about a hour to replace the 4. I had to use (2)35volt & (2)50volt cause radio shack only had 2 of each and it works like a charm. This TV has been in storage for 6 months until i found this article on the problem. Cant say thanks enough!!!!!!!!!!
Posted on Jul 14, 2008
  • 192 Answers
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Posted on Apr 26, 2009
Is there a way to cast screen wirelessly to my Emerson tv model LC195EMX
Amie, There is a way, check links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Best Wireless HDMI Video Transmitter
Send Your Cable TV Signal Wirelessly to Another Room
wireless tv transmitter
How to Watch HD Cable TV service Wireless on 2 TVs works for PS3 XBOX too
Mar 01, 2016 | Emerson Televison & Video
We bought a chomecast router for this product and cant find a code to connecr it
have had TV's a long time and still do not need a router for one .just a good outdoor antenna .
Nov 05, 2015 | Samsung UN32F5000AF 32 LED 5000 Series TV...
How do I fix?
Sounds to be a firmware corruption. Update its firmware with latest version than it have now. Gopakumar Gopalan Google
May 09, 2014 | Polaroid Televison & Video
Flat screen tv,,,,trying to hook up the directv...when i turn tv on, it says no signal. not sure why i cant chng channel?
there is nothing programmed in, you must do this first. Also have a good tuner or direct tv operates off of different channels it must be hooked up and on first and then programmed if you are trying that way, or use input jacks or HDMI if capable
Jan 02, 2011 | Polaroid Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Channels will not change- 42
it means that only one channel save from your tv. press automatic search to search more channel from cable signal. now you can change channel.
May 29, 2009 | Polaroid FLM-4201 42 in. LCD Television
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Sep 09, 2007 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
