Question about Building Materials
Is it easy to install door frame and line up to stricker so door will close easy now i have to lift up on door to close.
How do I remove the front driver side power window switch on a 2008 Buick Enclave
Armrest Door Pull
Remove Rubber Cover
Remove 10mm *****
The first step is to pry out the plastic trim plate behind the chrome colored door release handle using a small flathead screwdriver.Then remove the 10mm ***** behind the plate using a ratcheting wrench with an extension bar attached.
Next pry out the rubber cover at the bottom of the door pull located in the center of the arm rest. Use a Torx T-25 (star bit) screwdriver to remove the two screws.
Remove Torx T25 Screws
2 T-25 Torx & 1 10mm *****
Pry Up Arm Rest Panel
Use a flathead screwdriver to pry up the rear of the plastic arm rest panel. There is a plastic hook at the front of the panel, so only pry it up from the rear edge.
Lift Rear End First
Plastic Hook At Front of Panel
Power Window Connector
After you lift out the arm rest panel, you'll need to disconnect the power connector for the window and door lock switches.
Push Connector Release Tab
Power Connector Unplugged
Two More T25 Screws
Push on the release tab with a flathead screwdriver and pull out the power window / door lock connector.Use a Torx T25 screwdriver to remove the two screws located below the arm rest panel.
Remove T25 Torx Screws
Outer Edge of Panel
Push In Center of Fastener
Then move to the outer edge of the door panel and locate the two small round fasteners. Use a small screwdriver to pop in the center pins of the two fasteners.
Pull Out Plastic Rivet
Black Plastic Fastener Removed
Remove Lower Fastener
Pull out the two plastic rivet fasteners and set them aside in a safe place.
Pull Panel Away From Door
White Plastic Pop Rivets
Pull Off Sail Panel
Grab the door pull in the arm rest and tug it towards yourself to disengage the pop rivet friction fasteners that hold the panel to the door frame.Move to the top corner of the door panel and pry off the triangular "sail" panel. On some vehicles, the sail panel contains the tweeter speaker.
Lift Panel Off Door Lock
Pull Out Door Pull Cable
Lift the door panel off the door lock button and tilt the top of it out towards yourself.Use a pair of needle nose pliers to gently lift the metal ball at the end of the door opener cable out of the mechanism.
Disconnect the door cable from the back side of the door panel.
Door Pull Cable Removed
Disconnect Power Mirror
Then disconnect the power connector for the side view mirror by lifting up on the release tab. Slide the power connector off the plastic anchor on the metal door frame.
Slide Connector Off Anchor
Unlock Connector
Connector Detached
Look behind the door panel and locate the large wire connector with the pink lever lock. Swing the lever open to unlock the connector and separate it from the socket.
Door Panel Removed
Power Window Motor
10mm Bolts
Now the door panel can be completely removed by lifting it up and off the door frame.To replace the power window motor, remove the 10mm bolts.
Stock OEM Door Speaker
Remove 7mm *****
The stock "OEM" speaker is held in place by a single 7 mm *****. Remove it with a socket and ratcheting wrench.
Pry Off OEM Speaker
Speaker Removed
Disconnect Power Plug
If the speaker is stuck to the door frame, gently pry it off with a small flathead screwdriver.Disconnect the speaker's power plug by pressing the release tab with the small flathead screwdriver.
Fits 5.25", 6.5", 6.75"
Re-installing Door Panel
According to the Crutchfield website, the 2008 to 2012 Chevrolet Malibu's front door speakers can be replaced withaftermarket speakers in the following sizes: 5 1/4", 6 1/2" or 6 3/4" speakers with the use of a bracket.If you'd like to reduce road noise, make your car quieter and also improve the sound from your speakers, I'd recommend applying some Dynamat Sound Deadener on to the metal door frame.
Re-Attach To Anchor
Plug In Power Side View Mirror
Re-Insert Power Connector
To re-install the door panel, first hold the panel close to the door frame before re-connecting the large wire plug. Swing the pink lever closed to lock it in place.Slide the socket for the power side view mirror back on to its anchor and insert the power plug.
Lock Power Connector
Pink Lever Locked
Re-Insert Door Pull Cable Ball
Insert the metal ball at the end of the door opener cable back in to the door handle mechanism.Slide the black plastic cone part of the cable back into the slot in the door opener assembly.
Door Opener Cable Reinstalled
Hang Door Panel On Frame
Gently lower the door panel down on to the edge of the door frame with the door lock switch through the opening at the top.
Line Up White Plastic Fasteners
Push On Sail Panel
Push Door Panel In Place
Move to the bottom of the door panel and line up the white plastic pop rivet fasteners with the holes in the metal door frame.Push all around the door panel to re-insert the pop rivet fasteners.
Re-attach the sail panel at the top corner of the door frame.
Push Panel Flush Against Frame
Insert Side Edge Fasteners
Insert Larger Piece First
Next move to the side edge of the door panel and first re-insert the larger piece of the two fasteners. Then insert the smaller "pin" piece of the fastener into the middle of the larger piece.
Insert Small "Pin" Piece
Install Lower Edge Fastener
Tighten 2 T25 Torx Screws
Re-Attach Power Connector
Insert Front Hook First
Insert and tighten the two Torx T-25 screws located under the arm rest.Re-attach the power connector to the plastic arm rest panel.
First insert the hook at the front of the arm rest panel and then snap the rear end in place.
Pop Arm Rest Panel In Place
Tighten 2 T25 Screws
Replace Rubber Cover
Insert and tighten the two T25 Torx screws into the door pull cup. Then replace the rubber cover over the two screws.
Tighten 10mm Door Handle *****
Replace Door Handle Trim Plate
Malibu Door Panel Replaced
Replace the 10mm ***** that goes above and behind the door opener handle and tighten it. Pop in the plastic trim plate behind the door handle.
Apr 10, 2016 | Buick Cars & Trucks
I can not shut the trunk door of my Lexus rx350? It won't close.
Look at the hinge pins can you with the door open move it up and down independent of the chassy. Also look at the stricker on the frame of the door to see how well it aligins with the latch on the door ,
The hinge pin system these companys went with sucked and most of them went with them to save money .
The good news is you can get the replacement part .
The bad news is its hard to replace and it will be no better then the one that you already had the door is to heavy and the pin is week
IT SHOULD BE A RECALL
Mar 08, 2015 | 2008 Lexus Rx 350
Dash reads back door open when its closed
What vehicle is this? The easy answer is that the door switch is not turning off. Open the door/s and check for a little rubber bump somewhere along the frame. Push it in manually and see it this turns off the warning light. If it doesn't you might have a short to earth somewhere. If it does, you need to adjust the switch outward a little.
Good luck.
Oct 09, 2014 | Cars & Trucks
How to adjust pass door of 03 blazer
Oh is the "A" Frame OK, also the door frame where the hinges are your looking for damage distortion creases etc.
As the body guys say a dent is fixed by reversing how it happened, so to me this will be a body shop job. Ask a friend in the know to have a quick look see.
Regards David
Dec 25, 2017 | 2003 Chevrolet TrailBlazer
Hello, I have honda accord ex, 1995 bottom driver side light kept blingking while am driving. Do you thing "Fuse" thks Jessie
I think your door might be adjust too far out and the door is not push the Door Switch in far enough when it's close. Adjust the door inward a little by loosing the stricker screws and tipping it in with a hammer. See picture below for Door Switch and Stricker.
good luck
Jan 21, 2011 | 1999 Honda Odyssey
I cant get the driver door to close i replaced the pin upper an bushings upper i still have to pull up on it to close the door
adjust the stricker bolt on door pillar . on door grap side of door move up - down to see if has play in door after replaced door pins -bushings
Nov 01, 2010 | GMC K1500 Cars & Trucks
My drivers door seems to be sagging from the front pivot point of the hinge which is causing the door to not open well. It has gotten so bad that I have to physically lift the door to open. It no longer...
Sound like what you need, is door hing pins, they go on the hinges, remove hing pine and brass bushing, install new ones, you will need a jack or some thing to hold the door up while you replace the bushing's and pin's.
Sep 02, 2010 | 1996 Ford Explorer
1993 Ford Explorer, Driver side door does not close good
you need to adjust what is called the striker located on the actual vehicle body
looks like a round piece of metal sticking out with a star head in it called a torx head
move the stricker out towards the latch on the door a little not too muck or the door will not seal all the way when shut
Mar 11, 2009 | 1993 Ford Explorer Limited
94 saturn door panel removel
Well, first you have to remove the outside door panel. To do this remove the door handle on the out side. Lift up the handle and look underneath. You will see 2 little round pins sticking in the handle. Take a small punch and push them up. The handle slides to one side and then off.
Next you need a torx wrench to remove the 10 panel bolts located inside the door frame. I think it is a 40 torx.
Once they are removed you can lift up on the door panel and remove. You can't get access anyother way. Inside door cover can only be remove by removing the outside panel and
taking the clips off. So, once you have the outter door panel off you will the workings. You will need a flash light. Check the throw arm that attaches the locking switch on the lock to the door latch assembly. More then likly that is all that came loose. If that is ok then you need to replace the door catch assembly. Not an easy project. If you can do it the part is about $50 from the dealer. You will need to remove the 3 torx screws attaching the assembly to the inside door frame. Disconnect all the clips that attach the arms. Installation is the reverse. NOT AN EASY JOB TO DO. Plan on a whole day to figure all this out.
Dec 09, 2008 | Saturn SL2 Cars & Trucks
Fuel filter
Passenger side along the frame rail (unibody i know but where the frame would be) right up close to the motor. its a squeeze and push and pull type but be careful with the plastic line there not cheap and they are probably brittle.
Aug 21, 2008 | 1991 Cadillac DeVille
Building Materials Logo
51 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
