Question about Maytag Washing Machines
75% of the time my Maytag Epic Z washer stops without finishing all cycles. The exception is the Rapid wash cycle, which work fine 90% of the time. What is the problem?
  • 409 Answers
SOURCE: maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Posted on Oct 03, 2008
SOURCE: maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
Posted on Jul 03, 2009
pride applia
  • 232 Answers
SOURCE: Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Posted on Aug 02, 2009
  • 12 Answers
SOURCE: Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
Posted on Oct 04, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag washer MAH2400AWW problem.
Hi and welcome to Fixya. Usually when a unit stops in mud-cycle and the motor buzzes there is something lodged between the wash tub and the outer tub.
Draining must be done manually before you can open the door. You can try dropping the drain hose down and gravity drain the washer. If that does not work then the only other option is to unplug the unit and disconnect the tub to pump hose. Be prepaired for an immediate water mess if you manage to get the hose completely free of the fitting all at once. You only need to drain it until the water level is below the door seal.
Once you get the water out open the door then sue a flashlight to search for what it is that is preventing the tub from turning.
Don't forget to reconnect and clamp the drain hose if you disconnected it and plug the washer back in.
Thanks for using Fixya. Kelly
Posted on Feb 08, 2010
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Epic Z front load washer stops working and flashes F-21 Error code. When I press "cancel" it then continues but doesn't go through the rinse cycle nor the spin cycle. When it's...
Hello, welcome to FixYa.
Based on your information posted I understand you have the Maytag Epic washer, correct ? The F21 error on these built by Whirlpool means an excessive drain time or excessive suds was detected as you may or may not already know.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is).
This will also instruct how to unlock the unit...though once the water is gone it likely will unlock without issue, if it is at all an issue. Many times it is, but it's just a by-product of not draining correctly.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for choosing FixYa. Please take a moment to rate the info provided here and a testimony on your experience here at FixYa today is appreciated.
Let me know if anything isn't clear or you need further assistance, Good luck.
Regards,
Macmarkus :)
Sep 26, 2011 | Maytag EPICz 3.7 Cu. Ft.
The front end load washer door wont open as there is water still in washer and not operating. what to do ..thx
Hi, Make sure it is plugged in properly, and let the cycle finish correctly. Try advancing the cycle control knob ( if it has one). I need a bit more info...
Feb 18, 2011 | Maytag EPIC MFW9700S Front Load Washer
Face Clothes and Towels are smelling bad after being washed and dried in my Kenmore HE3 washer and dryer. Have tried running an empty cycle with bleach only, washed small loads with hot water, pre-wash and...
Try running an empty heavy duty wash cycle with a pint of vinegar added to the water, run wash cycle for two or three minutes then turn the machine off for thirty minutes then restart and let finish the full wash cycle
Aug 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Error code "F".
The "F" code indicates an electrical problem, possibly a faulting part. Maytag does not offer any guidance on this. FYI - Could be a bad control board
Apr 18, 2009 | Maytag EPIC MFW9700S Front Load Washer
My Maytag epic he has F6 code
What is the model number of this unit. Should be inside the door on the frame. If you take off the bottom panel, there is a tech sheet in there that will tell you what that means. I don't know that one off the top of my head and I can't get at my work P.C.right now. It'll give good detail of what to look for on that tech sheet Let me know if you have any questions.
Mar 06, 2009 | Maytag EPIC MFW9700S Front Load Washer
My new Epic Z is only one month old
sounds to me like there is a short in the wiring or control board i would call the warranty company to come fix it
Dec 30, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
