Question about Humidifiers
I have a aircare humidifier ea1407 hd1409 the display keeps going to EE
Why is my Aircare tower humififier flashing CF??
clean filter, filter is blocked not letting the air flow through correctly, take the filter out and clean it with warm water and leave to dry before refitting, can use soak but not to much as can damage the filter threads. but warm water will do the job to remove the particles its picked up.
Jan 16, 2018 | Humidifiers
AirCare.condole evaporative humidifier, won't run, shows EE code.
If it has a humidistat in the power cord it may have gotten wet when refilling. Blow the water out, or remove the screw to open the small casing and dry it out. If it was wet, the unit should start running normally.
Dec 08, 2016 | Humidifiers
Looking for manual HM1865
This link should open the manual for you. I covers both the frog (the model you have) as well as many others. http://cache.air-n-water.com/manuals/crane-ee-3191.pdf
Mar 03, 2014 | Crane Frog EE-3191 1 Gallon Humidifier
Why does the crane elephant humidifier leak
The humidifier has just started leaking from underneath the trunk part and drips down the front side and pools quite a bit underneath the humidifier causing quite a wet mess. This just started after I ordered a replacement water tank. Any suggestions?
Feb 15, 2013 | Crane Elephant EE-3186 1 Gallon Humidifier
We have an Essick Air Humidifier Model EA1407. One water bottle empty's every day. Is this normal?
Ours empties both bottles in one day. That is normal for a dry house. If your problem is that only one bottle empties and not the other, make sure the bottle is properly positioned on the bottom cap valve. To check this, put in only the bottle that doesn't empty by itself when the console is empty. The bottle should "gurgle" as it starts filling the bottom of the console. If it doesn't, re-position it until it does.
Jun 19, 2011 | Essick Air Humidifiers
I need the instruction manual..i don't have it and i don't know how to operate the humidifier
http://www.crane-usa.com/manuals/HumidifierManual2008.pdf
This is the manual for all "adorable" crane humidifiers.
Nov 12, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
I have a WHITE residue all over the room where the humidifier is? what is this?
From the troubleshooting section of the manual(http://www.crane-usa.com/manuals/HumidifierManual2008.pdf): White dust appears and settles outside the humidifier: ? Area tap water may have too many minerals, change to filtered or distilled water.
Jan 14, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
No manual for Bonaire humidifier BCM 4510-U
If someone put it togetherm you can take it apart.
See if the dicharge grill slides up and the bottom vcan be pulled out like a window screen. If so, ,other panels may also do so in order to access the internals, Unplug unit when in the water or around fan. Do not run unit without panels in place. Any fan cleaning use something like 409 spray and rinse off with a spray bottle also. Keep water out of all and any electrical. Rinse and leave no cleaner in humidifier to be mixed with misting. Good Luck
May 17, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
Humidifiers Logo
126 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
