Question about Canon Office Equipment & Supplies
How can i solve the problem on canon ir 6800 which does not restart when i start it on i change the power cable and power supply but no use?
Noggin
  • 944 Answers
SOURCE: is the 350 watt power supply unit ok for EVGA Geforce 6800 graphics card ?
The big issue with a power supply unit rating is the total peak load that it has to deal with, which you calculate by adding all the rated loads of all the parts of your pc that are connected to it, and add yourself an extra 20% for luck. The motherboard, the HDD, the fans, the drives, USB devices, modem, and many more. If you have enough wattage left to accomodate your graphics card then it should be fine. If in doubt, for the cost it is always better to upgrade your power supply to a larger rated one, rather than overloading a smaller supply or causing low voltage problems with all your peripherals. Here is the link for your graphics card manual if you need it; http://www.evga.com/support/manuals/EVGA_GraphicsManual.pdf Check page 5 reference the supplemental power adaptor, and check your power supply has an connector for it. If you want to identify the power consumption ratings for each part of your pc, most will be written on the component somewhere, some in the manual, and some you have to guess by checking similar items ratings online. If you want help with this please post again and we can certainly try. Looking at the card, my guess is that a system that can justify such a nice card is likely to be pushing a 350w supply already, I'm guessing what your system could be like and I would put a 600w or more supply in it as soon as i had the cash to do so. post back all the details of your machine and i can figure it out if u like. This link takes you to some other interesting info about your graphics card. http://www.evga.com/support/knowledgebase/ Mostly a power supply that cannot deal with the demand will inform you by shutting down or committing suicide, although occasionally other components can be damaged by poor power supply, the chance is minimal with many newer items, and it should be worth trying. The fan performance of a power supply often governs how well it can deal with long periods of high load - give it a proper clean, and remember to check always that it is running. if you want, you can install another fan on the outside (blowing the same way), but unless you power it from a different source then you don't really help much. Instead of getting a larger power supply, you can just get another (perhaps from an old pc) and only use it to power the graphics card - best left outside the case for overheating reasons. Hope this all helps :)
Posted on Mar 20, 2007
Cogz
  • 1326 Answers
SOURCE: Need to locate the waste toner container on a Canon ir 6800
The waste toner bottle should be on the right side of the copier toward the rear of the copier. It is behind a pannel that is held in with 2 screws. Take the screw out & open the pannel & the bottel should be inside that opening it is a milky white container. Pull it out, it is rather large. When you dump out the toner make sure you have a plastic bag with No holes in it, it can be very messy if you are not carefull......Good Luck
Posted on May 21, 2009
  • 78 Answers
SOURCE: ERROR E000078-0001 PARA CANON IR C 6800
the HP sensor does not turn on within 5 sec after the of a HP search turn off then on the main power
Posted on Sep 12, 2009
Cogz
  • 1326 Answers
SOURCE: how to clear an error fo canon copier ir 6800 cn with an e000061-0001
A E000061 is a drum potenal problem. It means the drum is not charged up correctly. It could be as simple as replacing the two post corona wires and cleaning the grid or making sure the primary charge unit is installed correctly. It may also, be a broking grid or corona wire > you may have to replaced the primary charge unit??? It could also be the drum potenal sensor or the DC controller or the drum..... I'd go for the simple stuff first and you can not clear the problem till the problem is fixed > Before I forget, you can also, turn the drum potenal off in service mode... It's just a band aid, it will not solve the problem..... Good Luck
Posted on May 05, 2012
azzoom_in10
SOURCE: Hi canon IR 6800 CN
canon ir 6800cn error code e000100-0002 solution
Posted on Nov 13, 2012
How do i get the factory default setting for canon ir 6800?
Go to service and and clear the error
Asterisk * press
then press 2 & 8(Two buttons single time)
Again press Asterisk *
COPIER>FUNCTION>CLEAR>ERR
Then press ok an off the machine wait 1 minute and on the machine..
Jun 23, 2016 | Canon Office Equipment & Supplies
First i changed the fuse gear canon ir 6800 and put the fuse unit back to machine . when i turn it on the machine show the error 000005-000010 what can i do ?
hi . that error indicate that the cleaner roll ( in the fixing unit )is over . maybe there is a sensor disconnected or misplaced. check That section and clear error from service mode
copier / function / clear / err ok.
Feb 27, 2016 | Canon Office Equipment & Supplies
The LCD doesnt lit when i tern on the main switch on in canon ir 6800 cn
CHECK THE MEMORY OR THE CONNECTOR OF YOUR PANEL BOARD AND ALSO CHECK THE DC POWER SUPPLY.
Apr 07, 2014 | Canon imageRUNNER C6800 Copier
How to clear an error fo canon copier ir 6800 cn with an e000061-0001
May 05, 2012 | Canon Office Equipment & Supplies
Ir c 6800 erorr code e000021
A decent amount of E021 codes i have seen have been a locked up Developing unit. Remove your developing units and turn them by hand, if one wont turn replace it. Also i have seen a DC Power Supply Relay PCB cause this issue.
Mar 14, 2012 | Canon imageRUNNER C6800 Copier
Canon ir 3300 ,this has E000019-0000 problem ,how to solve it
canon ir3300 error code E000019-0000, hOW CAN I SOLVE IT ???
NO KEY IS FUNCTIONING NOW.................
mail at chandaxerox@gmail.com
Feb 19, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Error E000020-03a2 canon c6800
pls check the cyan deverloper if it irc6800.drum unit if it is irc3200
Mar 04, 2010 | Canon imageRUNNER C3200 Copier
23 people viewed this question
old marine
old marine
