Question about IBM ThinkPad T21 Notebook
IBM Thinkpad T21 Bios Password
I have a password on the bios for my IBM Think pad T21 but i don't know it, i cant use the laptop anymore.
does anyone knows how can i reset this bios password??
Lost password
theres like three different kinds of passwords on these laptops i believe.. do you see a lock on a black screen? if you do, thats a bios password. itd be kinda difficult to remove it, you need to create a password reader.. then delete it using another computer.. either that or unsolder the correct chip and resolder another one, you can find these on ebay.. i dont recommend u to do it if youre unexperienced with hardware.. check out this link
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Jan 13, 2010 | IBM ThinkPad T21 Notebook
Need to recover password
hi i hope this will help you, but be careful with these solutions..do this at your own risk.
here's the url:
Mar 21, 2009 | IBM ThinkPad T21 Notebook
My IBM Thinkpad is not switching on?
The error message relates to the date and time setting in the BIOS, it has a wrong due to a flat BIOS battery. The needs to be replaced and the date and time corrected,
The padlock symbol indicates the laptop's BIOS has been set with a password and you cannot enter and change the BIOS settings without this password.
Replace the BIOS battery with a new one, then boot up and enter your BIOS password, then change the time & date, then save and exit.
Mar 15, 2009 | IBM ThinkPad T21 Notebook
Need password
The password requested is the Power on Password and it is stroed on the AMETEL 24RF08 EEPROM chip.
The Power on Password is set from the BIOS configuration and removing the BIOS battery wil reset the BIOS to the default settings but will not remove the password.
There are no backdoor passwords available and IBM say the fix is replacing the motherboard.
You can hack into the EEPROM to retrieve the password but it requires electronic knowledge to build an electronic interface and running a program on a working computer.
For further info go to :-
Mar 05, 2009 | IBM ThinkPad T21 Notebook
IBM Think pad T21 Notebook can not boot!! Help please
Run IBM BIOS Setup
Utility to reset the time and date.
Jul 17, 2008 | IBM ThinkPad T21 Notebook
IBM Thinkpad T21 2647 8AU remove Administrative password
to remove the administrative password follow this link for all about removing admi password its free check it
http://www.kellys-korner-xp.com/win_xp_passwords.htm
then for bios password try to remove the cmos battry for while then put it back for some systems the password may not go off. in that case, the password is stored in a chip the 24co2 ic which i can not locate the actual position. thank u
n plz tell me the extend uv gone if this helps.
bye
May 26, 2008 | IBM ThinkPad T43 Notebook
Ibm t20 think pad
There is a company called pwcrack online that maybe able to help you out. If they can't help you would have to replace the motherboard which is not very econmical to do so.
Thanks
Todd
Laptop Guy
Apr 23, 2008 | IBM ThinkPad T20 2647 Notebook
Laptop is locked out
This works great
Forgotten Power-on password
If the Power-on password is forgotten
and the Supervisor password is known,
simply go into the ThinkPad BIOS setup
utility and reset the Power-on password,
otherwise try the following:
Turn off the computer.
Remove the battery pack.
Remove the backup battery. This is
located under the battery.
Turn on the computer and wait until the
POST ends. After the POST ends, the
password prompt does not appear. The POP
has been removed.
Reinstall the backup battery and the
battery pack.
Note: Some ThinkPad systems have the
ability to reset the Power-on passwords
in the ThinkPad BIOS setup utility if a
Supervisor password has been set.
Oct 30, 2007 | IBM ThinkPad T21 Notebook
Bios password
ibm think pad r40 bios password cracker
Oct 11, 2007 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad T21 Notebook Logo
920 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
