Cd player says "no disc" when some cd's inserted. Does play other cd's.
  • 1,381 Answers
Try a cd lens cleaning disc in there
Posted on Dec 30, 2016
CD player did not play when a disc was inserted.
Various things can cause a CD player not to play a disc which gets inserted. First of which is a bad disc, second is the issue relating to regions as certain regions require particular formats for their discs and finally is a dirty lens.
Try running a cd lend cleaner on the system and retry the disc.
Hope this solution has been helpful?
Jan 01, 2011 | Bose Audio Players & Recorders
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
    There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
    • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
    • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
    • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
    • If the disc still does not play, attempt to play a different, commercially-produced disc.
    • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
    • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
    • Properly reinsert the disc into the player.
    • Attempt to play the disc again.
    • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
    • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
    • Please use a Lens Cleaning disc and check if that helps.
    If the issue persists, please click hear to locate the repair facility near your area.
    Thanks for understanding. Please let me know if you require any clarifications.
    Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
    Sharp XL-HP515 CD Player won't play. Displays "toc read"
    take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
    Oct 09, 2009 | Philips CDR770 CD Recorder
    Will not play disc
    you may have a region1 player and are trying to play a region 2 disc or vise versa or if you are playing copyed dvds are they finalized.
    Jun 05, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
    Magnavox DVD Video Player DVD609AT
    DVD609AT:
    The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
    This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
    Playable Discs
    This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
    DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
    Region Codes and Color Systems as described on this page. Also, the Discs should have
    the following logos and should meet these standards.
    • CD-ROM
    • Compact Disc-Interactive
    (CD-I)
    • Compact Disc-Recordable
    (CD-R)
    • Digital Video Disc-Video
    Recordable (DVD-VR)
    • DVD-RAM
    • DVD-ROM
    • Super Audio CD (SACD)
    • Photo CD
    • Video CD
    • Video Single Disc (VSD)
    Digital
    Video
    Disc
    12 cm
    12 cm
    Approx. 4 hours
    (single-sided)
    Approx. 8 hours
    (double-sided)
    Approx. 80 minutes
    (single-sided)
    Approx. 160 minutes
    (double-sided)
    20 minutes
    8 cm
    8 cm
    (singles)
    Logo
    Maximum
    Disc Type Contents Playback Time
    Sound
    and
    Pictures
    Audio
    CD
    Disc Size
    Sound
    74 minutes
    Disc
    Segments
    DVDs are
    divided into Titles,
    which are divided
    into Chapters.
    Titles and Chapters
    are numbered.
    Audio CDs are divided
    into numbered Tracks, i.e.,
    a track may be one song.
    Unacceptable Discs
    If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
    the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
    DVD or Audio CD. The following Discs will not play on this DVD Player.
    • CD-ROM
    (CD-I)
    (CD-R)
    Recordable (DVD-VR)
    • DVD-RAM
    • DVD-ROM
    • Photo CD
    • Video CD
    May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
    Cd drive
    media player needs configuring,select all file types.reason it wont find songs previosly burned is probably because burned as compilation and not finalised.you can download a player called VLC (for free)it will play any file type a lot of which media player cant.whatever media you have it'll play
    Dec 06, 2007 | Computers & Internet
    Televison & Video Logo
    Top Televison & Video Experts
