Question about Seiki Televison & Video
I have a Seiki TV and when I put TV on TV it goes back to HDMI. How do I fix this?
    Top Expert:
  • Seiki Master
  • 75,462 Answers
Do a factory reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done..
Posted on Dec 31, 2016
Seiki tv stuck on HDMI input, will not accept coax Statellite Input.
Try to change inputs using the input selection button on the TV itself. It's ususally marked with an icon of a TV, with an arrow pointing in. There might just be an issue with your remote control input selection button, often a very much used button. I presume you've checked the batteries in the remote control.
Nov 06, 2017 | Seiki Televison & Video
I replaced the main board on seiki tv but now it won't come on
Put the main board back in and see what happens. If original issue is back then the replacement board is no good. If it also does not work now, then you screwed up some wiring while you were "fixing" unit.
Feb 23, 2017 | Seiki Televison & Video
How to reset Seki tv when it goes off and will not come back on
Seiki hard reset tv factory settings Flat Panel Televisions ...
www.fixya.com > ... > Flat Panel Televisions
Seiki flat panel televisions hard reset tv factory settings related questions and answers. Ask your Seiki questions. Get free help from flat panel television experts.
How to reset a seiki hd tv that keep reading no signal? - The ...
www.askmefast.com > Family & Relationships > Singles & Dating > Signal
To reset your seiki hd tv you just need to press on the menu: 0000 The TV will ....Getting to factory settings seiki tv ..... "How to reset seiki tv that reads no signal?
FAQ's ' seiki
Dec 19, 2015 | Seiki Televison & Video
Power indicator on, logo flashes briefly, but then no picture. What's wrong?
SEIKI Tv SC501TS has audio but no video, repair - YouTube
? 1:38
https://www.youtube.com/watch?v=cWpF4q_rBaw
Oct 19, 2014 - Uploaded by EurekaRecycler
SEIKI Tv SC501TS has audio but no video, repair ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD ...
LED TV Repair Main Board Overview Blank Screen-TV Has ...
? 2:57
https://www.youtube.com/watch?v=-TU2KSuect4
Mar 4, 2014 - Uploaded by ShopJimmy.com
Learn why your screen is blank and you have audio - No image LED TV Repair Review Main Board Problems ...
LCD & LED TV Repair - No Image & Blank Black Screen ...
Dec 13, 2015 | SEIKI Digital Seiki SE32HY10 32 720p...
How do I fix my hd TV when it works for a few minutes up to an hour or so, and then the screen goes black with no sound
Check out the power supply board. I suspect that after it gets hot after a while it shuts down due to a defective component that is heat sensitive. Problem is that you have an intermittent and you have to wait for the hassle to appear, if and when.
Aug 21, 2015 | Seiki SE551GS 55"led...
How can I hook up my lap top to my tv ?
depending on your tv you can use VGA cable or S-VGA or if its a new tv you can hook it up HDMI cable its all up to you and what u have
Jan 25, 2015 | SEIKI Digital Seiki SE40FY27 40" 1080p...
Seiki TV has NO SIGNAL message. I changed the main board but that didn't fix it. Light goes from red to blue when I turn it on. Sometimes after about a half hour I'll get signal but sometimes it'll...
Do you have cable ,satellite? Does the no signal come up on all inputs?
Reset cable or satllite box by unplugging from the wall. If HDMI is being used unplug and replug HDMI at d both ends.
Dec 29, 2014 | Seiki Televison & Video
Can i hook up a seiki model SE39UY04 to a comcast HD box useing only the HDMI cable and which slot on the TV do I use
You should be able to. You should be able to hook the HDMI cable into the tv, than go to "TV Input" and select "HDMI 1" "HDMI 2" or "HDMI 3" depending on which input you used
Nov 30, 2014 | Seiki 39" Class 4K 120Hz LED Ultra HDTV -...
Televison & Video Logo
105 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
ka4iup
ka4iup
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
