Question about Miscellaneous
I NEED TO KNOW IF MY CHARGE CARD HAS BEEN USED RECENTLY. I AM NOT THE ONE WHO USED IT IF IT HAS BEEN USED THIS YEAR!
Need code for radio
If you have lost the code card , your dealer will be able to find it for you, You will need make, model, frame number, year and paper work showing owner ship. There may be a charge.
Jun 05, 2016 | Cars & Trucks
I just saw Amazon Prime charge of $99 on my credit card. I don't remember sign up for this nor do I think that I have used Amazon Prime. When did I ever use this Amazon Prime?
If you ordered ANYTHING from Amazon, you automatically signed up for PRIME and it is not free. When you check out, you need to uncheck the box that subscribes you to prime or it is automatic. Go back to the website for amazon and look for CONTACT US. Then get a hold of them and cancel prime. Unless you buy a lot from them it is not worth the cost. IT is a membership and you get billed once a year.
Dec 21, 2015 | Computers & Internet
How can I fix my rechargeable portable spotlight/flashlight after no charge for 1(one) year?
The spotlight/flashlight battery may have failed as a result of being unused and not charged periodically.
Dec 12, 2014 | Vector Camping, Backpacking & Hiking
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
May 12, 2011 | Nikon Coolpix S4000 Digital Camera
How long does it take to charge battery. how do I know when we need a new battery
If ur battery is less than a year old,it take about 6 hours to fully charge the battery,after a year the battery weaker,it take like about 8 to 10 hours for a fully charge.The used of the DVD player last only 10 to 20 of used of the DVD player or DVD player the charge light don't lite at all.
Dec 13, 2010 | Durabrand PDV-709
I fully charge the battery and recently it lasts just 2 days in the camera whether being used or not. the camera is just 5 months old. Would this be abattery or camera fault
Mine is over a year old. I typically need to charge it once a month if not in use and otherwise after about 800 shots without flash or 300 shots with flash.
Oct 26, 2009 | Canon EOS 450D Digital Camera
HP Ipaq does not turn on
Ufortunately, the battery is likely the culprit.
You can try removing the battery overnight, then leave on charger for at least 12 hours.
These batteries generally require replacement every 1-3 years. They deteriorate quite rapidly if left unused/uncharged for extended periods of time (like a year!)
Jun 25, 2009 | HP iPAQ HX2490 Pocket PC
Compaq iPAQ 3850 Not charging/turning on
Try this - don't give up Leave it charging, even if it takes three days. I sold one a few years ago on ebay and the buyer was insistent it wouldn't charge. Eventually it did start charging and there were no more problems.
Jan 24, 2009 | Compaq iPAQ H3850 Pocket PC
Card Cannot Be Used message?
Just so you know, I have this problem also. Anyway, the only thing that works for me is to turn the camera on WITHOUT the card inserted, then insert the card. After this, it will let me take ONE photo, video, or noise clip before it gives me the error again (strangely enough, I just figured out this solution a couple hours ago as I was browsing a listing for a similarly infected camera on eBay).
For a permanent fix, the "cheap camera repair man" can repair both the menus and the error for 55 bucks on his website (DynamicCamera.com).
By the way, you only need one account, and one question.
Nov 21, 2007 | Nikon Coolpix S1 Digital Camera
Miscellaneous Logo
20 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
