Can I get a new remote for this item - Televison & Video
  • kakima Dec 30, 2016
    Hi Janet Crowell, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What is "this item"?
When I press the ok button on my remote to select a channel or recording, the on-screen cursor jumps down to the next item listed and I am unable to select the item I want.
First thing to try is the batteries in the remote. Use new fresh ones, the second this is to see if it is a radio or light controlled remote. If it is radio then you have something causing interference. If it is light control then the remote is probably bad. There are parts in the remote that don't survive falls in some cases
Jan 15, 2016 | Humax PVR9300T HD DVR
Optimus stereo receiver universal remote codes
go to link below and click the green "Notify Me" button when this item is stocked. We will inform you when we put one in stock. You must purchase a new OEM remote, universals will not work. OPTIMUS STA3750 3760 Remote Control
Apr 17, 2014 | Optimus Sta-3750 Sta-3760 Stereo Receiver...
Can I purchase a replacement battery door for a RM-C1273G remote or do I have to purchase a wholw new remote control?
I don't know of anywhere that you can purchase just the battery cover by itself. You may get very lucky and find someone who is selling a broken unit online just for parts, but this is highly unlikely given the relatively low value of the item.
Here is a link to an exact replacement remote control currently available on Ebay for $20 US:
http://www.ebay.com/itm/JVC-RM-C1273G-MONITOR-REMOTE-CONTROL-/230363562526?pt=LH_DefaultDomain_0&hash=item35a2bd021e
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and item at the website indicated.
I hope that was helpful to you, good luck and take care.
Aug 21, 2011 | JVC Televison & Video
Can't turn on and off without manually going to unit. Have remote rc18sr. System still rocks, however went online to try for a new remote, i guess this is obsolete.
Marantz RC18SR Remote Control RC-18SR
Item condition: Used
Time left: 21h 0m 48s (Feb 17, 201111:51:43 PST)
http://cgi.ebay.com/Marantz-RC18SR-Remote-Control-RC-18SR-/180627142815?pt=LH_DefaultDomain_0&hash=item2a0e37789f
Marantz RC18SR Remote Control RC-18SR Item condition: Used Time left: 21h 0m 48s (Feb 17, 201111:51:43 PST)
Feb 16, 2011 | Marantz AV-560 Receiver
Looking for auto restart on carrier 40GKX series
Can you please check if the remote handset is this?d6f691e.png if yes, follow below
• Connect the system to the electrical current.
• Press the button M and of the remote control and keep them pressed down for at least
5 seconds.
• The clock digits show the first configuration item (rAdr = remote address) and the temperature
digits show the default value of the respective configuration item (Ab = control of both indoor
units).
• Press the button M repeatedly until "ASt " appears.
• Press the buttons ∧ or ∨ to change the default value (OF) to the new value (ON).
• Press the button to send the new configuration to the unit.
• Press the button to exit the configuration menu.
To see other available configuration options, consult the table.
Item Viewfinder display Explanation Description
1 "rAdr" "A": remote unit A Remote address of indoor unit A.
"b": remote unit B Remote address of indoor unit B.
"Ab": remote units A and B Default address of the two units.
2 "UCFG" "HP": Heatpump Default address and heatpump
"AC": Cooling only Changes the cooling-only address
3 "UAdr" 1-240 with an increment of 1 Address of the CNN unit.
Default = 1.
4 "ZONE" 1-240 with an increment of 1 Zone number.
Default = 0.
5 "GFdn" 1-240 with an increment of 1 GFD number.
Default = 1.
6 "A St" "OF" : Shutdown mode Select the function mode after an
"On" : Automatic restart electrical power failure.
If no button is pressed for 30 seconds, the remote control automatically exits the
configuration menu and the entire procedure must be restarted.
NOTE
Feb 19, 2010 | Carrier Heating & Cooling
Can I order a new remote ?
Some TV shops have extra remote stacked up there collecting dust. You may even find one for your particular device, and they probably sell you one for a few bucks. I used to work in an electronic shop where they have lots of remote from items they were never able to fix or customers never came back for them. Most TV shops usually take the remote control along with the item when it is dropped off to be fixed. They may junk the item but they always keep the remote so there is a good chance you may find one there. Make sure you bring the your dvd vcr combo with you, and some batteries so you can test it.
Nov 25, 2009 | Samsung DVD-V3500 DVD Player/VCR
Code problem
turn on item you want programmed.press set up.press button for item on remote.press power button up to 300 times slowly until tv ect... turns off.hit enter this should work
Jan 30, 2009 | Directed 434MHZ Remote Control
Tv
There should be a guide with the new remote. If not call and or go to the store that you purchased this item for, and ask for one.
Mar 29, 2008 | Jensen JER-422 Universal Remote Control
Sony K60XBR800
Model
KF50XBR800, KF60DX100, KF60XBR800
RESOLUTION
Yes. Try the attached procedure. This has proven to be very effective.
Enter the service mode by pressing Display, 5, Vol +, Power.
Press Menu and go to Setup. Select Image Revision and set to 1. Press Menu once to exit the menu screen.
Cycle thru the service mode using button 5 until you get to D-GM TG. Press number 1 on remote once. You should now be at the 1 POS CTL. Change data from 11->1.
Push the number 1 button on the remote 14 times until you are at 15 ENB POS. Change data from 5->23.
Push number 1 button on the remote 8 times until you are on item number 23 PRG POS. Change data from 0->2. Write the data to memory by pressing MUTE, ENTER.
Push number 2 on remote 6 times until you are at H POS SHIFT. Proceed with the following steps very carefully. 0 VAR POS-CTL=0. Press number 1 on remote. Change D-GM HP item 1 from 9->11. Write the data to memory by pressing MUTE, ENTER.
Press 4 on remote. Change to 0 VAR POS-CTL=1. Then press #1 on remote. D-GM HP ITEM #1. Change data from 9->11. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=2. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=3. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=4. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=5. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=6. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=7. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=8. Then press #1 on remote. D-GM HP ITEM #1. Change data from 5->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=9. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=10. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=11. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=12. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=13. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=14. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=15. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data.
Press #5 on remote 6 times back to catagory D-GM TG INV CTL. Press number 1 on remote once to the Catagory D-GM TG 1 POS CTL. Change the data value to find the best setting where no double images, ghosts nor merged colors appears. WRITE DATA.
Press #2 on the remote 11 times to the Option-E O Lamp Time. Note the current value and write it down. Add 2000 to the value (ex if 1356, than 1356+2000= 3356). Divide this number by 100 and write this value to the Option-E 11 P CTL SHT1. For our example above we would have 3356/100= 33.56. So we can round to 34.
Now add 50 to this number. In our example we would have 34+50=84. Write this value to the Option-E 12 P CTL SHT2. Make sure to write the data.
Select AUTO in the menu for the Image Revision setting and exit the menu screen. Confirm that the picture is fine.
Feb 05, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
