Question about Watches
Instruction manual for Biden watch model # B 1060?
Is there an instruction manual out there somewhere for this watch? Thank you
If you need an instruction manual for some watch, you can do a Google search, specifying make and model of your watch.
Do not forget to give full details/numbers of your watch, or it can turn out you will get the wrong manual.
Oct 28, 2015 | Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
I have lost the instructions for my sportline duo 1060
Hello spikey_93,
You can download the manual for your Sportline 1060 from this link:
Sportline 1060
I hope this helped you.
You can rate my answer if you find it helpful.
Sep 27, 2011 | Sportline 1060 Unisex Duo Heart Rate...
My duo 1060 displays a Z symbol on the screen
I had the same thing. I called tech support for the "z" explaination. It means that one or both of your zone alarms are turned on.
May 24, 2011 | Sportline 1060 Unisex Duo Heart Rate...
Where I can download manual for Invicta 2732 watches
Download a copy of that Instruction Manual ->click HERE
May 02, 2011 | Watches
Need the instruction manual for model 5392
Go to the Invicta web site (www.invictawatch.com/) and put the cursor over "collections" and another menu will appear. Select "instruction manual" and on the next page select the PDF file at the bottom of the Invicta logo.
An instruction manual appears that cover all their watches. Read the section that deals with your watch.
Jan 31, 2010 | Invicta Watches
Instruction manual required for diesel watch DZ 7033
i have found the solution by visiting this site
http://store.dieseltimeframes.com/text/content/diesel/DieselENGLISH.pdf
All diesel watches manual instructions or (guide)
jamil soomro
toronto
Mar 02, 2008 | Diesel Audio Diesel Watch
Watches Logo
477 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
