Question about Amazon Tablets & eReaders
Connect echo to pad - Amazon Tablets & eReaders
Why can't I get Alexa to sync through my home wifi connection?
Amazon.com Help: Can't Connect to Wi-Fi
https://www.amazon.com/gp/help/.../display.html?...
Amazon.com, Inc.Make sure your Internet connection is not down. Restart your router and modem to solve most Wi-Fi network issues. Move Amazon Echo closer to your router ...
Amazon.com Help: Pair Your Mobile Device with Amazon ...
Dec 11, 2015 | Tablets & eReaders
I forgot my I pad password and my pad is locked
Factory reset! Connect to PC and log into iTunes, you can reset from there!
Jan 15, 2015 | Apple iPad HD
How to connect asus memo tab to tv
The ASUS Memo Pad has a Micro HDMI port next to the Micro USB port. Get a Micro HDMI to HDMI cable and you can connect the ASUS Memo Pad to your TV.
May 23, 2014 | ASUS Eee PC T91MTPU17BK Tablet
Connect to ipad
You don't assign an IP address to your iPad, it has one assigned to it by your router.
Open the Settings app on your iPad. Make sure Airplane Mode is OFF. Tap Wi-Fi. Make sure the Wi-Fi switch is ON, Ask to Join Networks is ON. Your in-home wi-fi network should be visible in the list titled Choose a Network.... Tap its name and provide the network password required by your router.
If you don't see your local router listed, it may not be properly configured.
Mar 10, 2014 | Tablets & eReaders
Wifi will not connect
Check the tools maybe it is in mode of or en mode plane turn on it or turn of the mode plane or restart the android factory pad and it goes to work again
Dec 25, 2013 | ASUS MeMO Pad HD 7
My asus transformer pad will not connect to wifi. I have done the factory reset and it will not even list a wifi list to connect to.
Obviously your WiFi is not enable. Check your settings and make sure your enable your WiFi. Then you will be able to see all computers (WiFi) around you.
Nov 02, 2013 | ASUS Transformers Pad Infinity TF700T
Tablets & eReaders Logo
24 people viewed this question
Top Amazon Tablets & eReaders Experts
Lesley Cameron
Lesley Cameron
castletech
castletech
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
