Question about Refrigerators
Fridge does not switch off, new thermostat installed
What is the problem if i fit a new domestic defy fridge thermostat with the same part it still stays running and not cycle.
what temp is in the fridge around 4 degrees and freezer -18 degrees and does the eveporator fully flood with with refrigerant if yes then try checking defrost timer is moving from its position also check is both fans runs
Oct 04, 2016 | Refrigerators
Hotpoint RLA64T fridge freezing up after new thermostat fitted
WHEN U TALK ABOUT THE THERMOSTAT U MEAN THE COLD CONTROL THERMOSTAT OR DEFROST TIMER THERMOSTAT? WHEN UR PROBLEM SOUNDS MORE LIKE THE DEFROST TERMINATOR OR BAD HEATING ELEMENT, LOCATED ON THE FREEZER EVAPORATOR COILS? IF ITS STAYING ON ALL THE TIME U HAVE A DEFROST ISSUE? OR BAD SEALS ON DOOR AND DIRTY COMPRESSOR
Aug 02, 2014 | Hotpoint Refrigerators
Smeg FAB28QRI thermostat not restarting fridge unless I hit side of fridge! Do I need a new thermostat?
It could be a loose wire on the terminal of the compressor. Also check for loose wires on the thermostat. If that is ok, the thermostat could be bad because it is a temperature controlled switch that turns the compressor on or off.
Jun 14, 2014 | Smeg FAB28QR1 Retro Fridge with Freezer...
Change thermostat on RM6401 electrolux fridge
You have to take the unit apart to get to the coil in order to detach the old one and install the new one. There is liquid in the coil dont kink it.
Jul 10, 2013 | Refrigerators
Hotpoint fridge RLA30 frozen milk on lowest setting
sounds like you need a new thermostat for your fridge. If your fridge wont shut off on its own than yes its most likely your T-stat. Hope this helps
Feb 15, 2013 | Hotpoint Refrigerators
Replacing a fridge thermostat of a Smeg FC40RX fridge freezer
DO NOT ATTEMPT THIS METHOD UNLESS YOU UNDERSTAND ELECTRICAL SAFETY. The thermostat is behind the cooling element at the back of the fridge compartment and it connected to the dial at the top front of the compartment that controls its temperature setting. Remove the front plate to access the switch and you will see the wiring that goes to the thermostat. Connect the two wires to the thermostat and if the fridge does not start the thermostat is faulty. Replacements are available, but you may need to do some hunting on line. With the power off this time, securely tie a few feet of string around the thermostat wiring at the switch. carefully loosen the cooling element to free the thermostat and pull it free. Now tie the string to your new thermostat and pull the string back through so the wiring is pulled into place. Put everything back the way you found it and, after a short while, enjoy a nice cold drink.
May 12, 2010 | Refrigerators
Which wires go wear when installing a new thermostat in my mini fridge?
In a mini fridge there are only two wires to the thermostat. I really does not matter which wire goes were because all it does is turn it off and on. Sea Breeze
Aug 26, 2009 | Haier HSA04WNC Compact Refrigerator
Thermostat not working in my Santo fridge
yes
it is a requirement as they are not repairable
you have to consider the cost against lost food and the cost of anew fridge
may be possible to get a thermostat to suit from e-bay
Dec 05, 2017 | AEG Santo U 86000i Compact Refrigerator
Samsung SR-L39 fridge freezer switching off
replace the thermostat of the freezer
Sep 16, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
