Question about Dyson Vacuums
My hand held dc 16 will run for a few seconds then the red light comes on why
  • 10 Answers
SOURCE: DC 17 Animal No suction on hand held hose
There is likely a blockage in the pipe. Try pushing something through taking care not to perforate the pipe.
Posted on Jun 21, 2009
  • 5 Answers
SOURCE: my dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Posted on Oct 29, 2009
Testimonial: "Thanks for that, It does look like the battery is shot. "
beltronic205
  • 1474 Answers
SOURCE: my dyson dc 16 hand held vacume stops & starts
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Posted on Apr 01, 2010
promo7uk
  • 19 Answers
SOURCE: I have a dyson hand held that shuts off after just
yeap..... i just found a fix for this ,, its mad how easy it is to fix as well...and it works 100%,,,
now dyson implemented a filter magnetic switch if u take your filter off you will see a small magnet in the corner,, u will notice where the magnet is behind it is rased platic,, now,,that the problem on the main board the transistor that picks up magentic signal from the filter is dud,!
dont ask me why it happens,, its a pain i know.,.
now take off collection pot for dust now take battery off.
now where the serial number is theres 2 hex screws that need taking out..
now u will see a small pcb board.. remove with one tiny security screw holding it in,, once removed pull both red plug off thats the digital motor plug.. and white plug which is vcc..to battery,, once u have done this pull the board down and back gently. as there is a long bit of board that goes up the back of the dyson plastic be very carefull pull this out.. now the long and thin pcb board that is hidden is what we need there is a tiny transistor,,, we need to remove this carefully..once removed,, we solder a thin wire from 2 point A+C need to be soldered together with a thin piece of wire, it will not harm the motor.. as long as u keep it clean,,
these points corolate to the transistor,,
A
B C
SOLDER AND A+C WITH A FINE PIECE OF WIRE NOW,, AND WALLAH... fixed put it all back together again,,, charge the battery,, and your away,,, working again,, if not u have other faults.. but 99% fix this with flashing red led,,,!!
Posted on Jun 24, 2010
  • 126 Answers
SOURCE: Hi my dyson hand held
take it apart and look for some trash might be rapped around the motor,because if the motor heats up it will shut down to keep it from burning up
Posted on Mar 31, 2011
My dyson shuts off after just a few seconds of run time.
Make sure the charger is operating. Then if it is, look at a failed battery.
Jan 13, 2015 | Dyson DC16 Root 6 Bagless Handheld...
Runs for a few seconds, then stops
Hi Bente, it's Jack at Dyson.
DC16 was the first Dyson handheld vacuum, launched back in 2006. It would have come with a 2-year guarantee, but due to its age it's likely that this has expired now.
However, our experts would be happy to take you through some quick diagnostic checks when you have your machine to hand. This will help determine which part may be at fault - and therefore, what may need replacing to resolve the issue.
If you would like some advice, you can reach our team of experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 20, 2014 | Dyson Dc 16 Root Handheld Vacuum Cleaner
Hi my dyson hand held dc 16 runs for 10 secs then for 3 secs until you let it rest, then it does the samething again
Mar 31, 2011 | Vacuums
My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
Apr 01, 2010 | Vacuums
My dc 16 rechargeable vacuum won't work
Oct 27, 2009 | Vacuums
My DC 16 will only run for a second each trigger pull. The battery is fully charged, it has plenty of suction, just wont run for more than a second. I cleaned the filters.
I had the same problem with my Dyson DC16, where it only runs for a few seconds at a time with each trigger pull. My husband called Dyson (Canada) and without hassle they shipped us a replacement part which I just received this morning. The replacement part sent to us is: DC16 Main Body with Rating Plate. It is also under warranty for 1 year. The great customer service makes up for the flaw in the machine. Also, Dyson is aware of the problem. Hope this helps.
Oct 25, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Motor running good but the water isn't coming out of either the bottom or the hand held tool
make sure your recovery tank is pushed down snug,somtimes it just need to prime itself,I had the same problem with my hand held tool, and that seemed to do the trick,after it pushed down,turn on power then wait about 10 seconds then turn on heater. I hoped this helped.
Oct 03, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
24 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
