Question about Altec Lansing Audio Players & Recorders
Can I connect my altec Lansing soundbar fx3020 to my home stereo if so how exactly would I do that ?
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Posted on Nov 20, 2008
SOURCE: Altec Lansing PT7031 - ''Panel Key is Locked''
With the unit turned on...
Press the following front panel buttons in sequence within a 10 second span:
[Vol+] / [Vol-] / [Vol+] / [Vol-] / [Vol+] / [Vol-]
Successful unlock is indicated when the front panel led's flash.
Posted on Jul 01, 2009
  • 7 Answers
SOURCE: output board for Altec Lansing ADA995
I've managed to fix the amp in the ADA995 when I blew the rear channel amp. There is a design fault with the voltage regulator that causes it to run very hot, which frys the plastic housing glued near it, which corrodes the circuit board trace.
Getting the sub/amp apart is a *****. But doable. You need to not only remove the screws in the back under the flat grills, but ALSO 3 screws behind the top speaker that also hold the amp in place. And getting the power supply out is another rather difficult procedure, which is needed if you want to run the amp on the bench to troubleshoot.
The amp chips are available, though no NTE equivalent, and replaceable.
Posted on Apr 22, 2012
SOURCE: Altec Lansing ATP3 broken speaker wire ORANGE connector/jack.
Here you go
Posted on Aug 27, 2012
I want to connect ADA-995 speaker system to stereo
You don't. They're already amplified via the amp that's inside the subwoofer. They're only designed for a headphone output on a PV or portable audio player
Apr 03, 2014 | Altec Lansing Audio Players & Recorders
Altec lansing connect
IM600 Compatibility: iPod mini; iPod classic 3G, 4G, 5G, 5.5G, 6G; iPod nano 1G, 2G, 3G, 4G; iPod touch 1G, 2G; auxiliary input connects to any CD, DVD, or MP3 player using a stereo mini-plug. If you have a mini-plug port on the IPhone which I believe you have; then attach a male to male plug in between the two devices. Take to Radio Shack for correct line plug.
Feb 09, 2014 | Altec Lansing Technologies Audio Players &...
Can I connect this to my tv? If so how-can't figure out how.
Sure, if your TV has some kind of audio outputs (and volume controls) for the "audio 5.1 inputs" you see in this picture.
You COULD adapt the probably-present stereo audio from your TV for use with the front channels . Stereo.
May 12, 2011 | Altec Lansing VS3251 Speaker
No sound
Well, i connected my stereo speakers to my computer but i didnt feel like getting the cords so i made my own. i used a cord that uses the headphone jack and used a red and white audio cord for the other end and connected them and it works fine.
Oct 05, 2009 | Altec Lansing ACS 495 Computer Speakers
Connecting an Altec Lansing ADA995 subwoofer system to a stereo
I have this exact Altec Lansing speaker system and I'm currently just using it with my Dell computer. But, I know you don't have to install these speakers to any high powered receiver for good sound quality. The subwoofer has two separate 200 watt RMS combined amplifiers built in for it's single knob controlled dual 6.5" bass drivers and 2-way magnetically shielded satellites, which are amplified together by any source that has an analog or digital volume control. The speakers act as a preamp receiver to any volume or frequency tone level controlled audio source. These input sources can also equalize the speakers receiving input signal for bass, treble or mid-range adjustments. You only need to obtain the proper adapter to hook up all the speakers to your desired component or device. Besides a computer, for example a TV with a variable audio out function or a mp3 player will work. The adapter that i am referring to is similar to what is included with certain 5.1 Logitech brand computer and multimedia speakers specifying gaming console and TV connecting. It has all three color coded 1/8" connector inputs on one end and RCA jack outputs on the other. This can be purchased more easily online then offline at stores such as Ebay for a fairly inexpensive price. However this adapter will not decode true 5.1 surround, but instead give a 5 channel stereo effect. I guess if one was looking for an inexpensive alternative solution to purchasing traditional high end home entertainment audio equipment, the ADA 995s are one of few computer speaker models in my book that can do a decent job.
Jun 19, 2009 | Altec Lansing ADA995 Speaker
I am not sure how to connect altec lansing vs3251 5.1 with my tv
U can connect it by a Y connector. Its a 3.5mm stereo jack on one end and the other end splits into two RCA sockts. So u can use these RCA sockets to connect to feed the audio output from the TV. thats all.
Apr 10, 2009 | Audiovox Audio Players & Recorders
Apr 04, 2009 | Altec Lansing PT7031 Computer Speakers
Connect Altec Lansing ADA745 to HD TV RCA output for home theater
It won't work like this due to this being a computer only speaker system. It requires the drivers to work with a computer & a Home theater does not recognize the format. Sorry.
Feb 25, 2009 | Altec Lansing Multimedia Computer Speakers
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
