How do I remove subtitles from my TV channels the blue button will not work on my 12v cello DVD remote
    Top Expert:
  • Televison & ... Master
  • 44,097 Answers
The "subtitles" are closed captions (CC) that usually are enabled/disabled during initial set up.
Posted on Dec 31, 2016
What button gets rid of subtitles that have just appeared on my tv. I must have pressed a button to start them but i dont know which one?
You are referring to closed captioning (CC) which is enabled/disabled by a button on the remote or by selection/cancellation during initial set up.
Oct 07, 2016 | Samsung Televison & Video
Cello tv stuck on standby
have you tried pressing one of the channel number buttons on the remote? Very often that has the same effect as pressing the On/Off button. And are you switching on by remote maybe thats knackered try switching on on button on tv, or unplug the TV from the wall for 30 seconds
Apr 05, 2016 | Televison & Video
Is there a way to access the subtitle button on a philips dvd player using the chunghop RM-88E universal remote control? Please help :(
Aren't you trying to select closed captions (CC)? If so, turning off the TV sound will cause closed captions to appear after a brief pause. Naturally, your TV has to be capable of doing this
Nov 02, 2012 | Televison & Video
Subtitles on screen
You have turned on closed captioning (not subtitles). You should have a CC button to turn it off
Oct 05, 2012 | One For All URC-3021 Remote Control
Hi I have a Toshiba CT-90326 Television. How do I disable the Audio Description on it? Thank you
Hello Clare,
CT-90326 is actually the model number of the remote control rather than the TV. It doesn't really matter as the correct button on the remote is more relevant than the actual TV.
The Audio description is a feature of the closed-caption/subtitle settings on your TV. You should be able to switch off the audio description by pressing the "SUBTITLE" button on the top row of the remote control. Each time you press this button it will cycle between ON and OFF.
If this doesn't work, it's probably because you are using a cable/satellite/digital receiver. If this is the case, look for a button on your cable/satellite/digital receiver remote control marked "CC" "CCD", "SUBTITLE".
Please try the above and then reply to me from within this page. Please state the model number of the TV and any cable/satellite/digital receiver you are using if/when replying.
Thanks,
BElectric
Jan 28, 2011 | Toshiba Televison & Video
HOW DO I REMOVE THE SUBTITLES FROM MY SONY BRAVIA
The Subtitle option is available only with the connected devices like DVD Player, Blu-ray Disc Player etc. The option avaialble in the TV is known as Closed Caption. The Closed caption option can be turned off by selecting the options below:
Press Menu button on the TV Remote. Select, Setup settings. Then select Caption Vision option to OFF. This option is for turning off the Closed Caption option in the TV to OFF. For disabling the Subtitle option in the connected devices like DVD Player and Blu-ray Disc Player, press the SUBTITLE button on the supplied Remote continuously to select OFF.
In few of the TV broadcasting channels the Subtitles cannot be turned OFF as this is being broadcasted with the channels.
Good Luck! KenSolutions
Oct 28, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How can i remove unwanted subtitles the movie is in english and the sub titles ate very distracting
Usually, if the subtitles are from your dvd player, you can go to the main menu, select "languages" or "setup" (depending on the dvd), and find the subtitle option. You should be able to shut them off there in the menu. If the subtitles are there because of your tv, there should be a button labeled "cc" on your remote. If you press this key a few times, it should eventually read something like "cc off" on the tv screen. I hope this helps, and good luck! Sincerely, Der Strom
May 10, 2010 | LG DR-4912 DVD Recorder
Add subtitles samsung
Must tries mutilple channels,pushes the remote button CC 1,2,3 on every channels.Sometime channels don't have captioning.
Feb 24, 2010 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Jun 04, 2008 | JVC AV-32260 32" TV
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Sep 03, 2007 | Onkyo TX-SR604 Receiver
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
