How much is s battery? Adaptor? - Computers & Internet
  • kakima Dec 30, 2016
    Hi Kekamack65 , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    For what?
My sonyericsson Experia X10 not charging
first of all connect your adaptor to the phone,remove the battery and check the battery terminal voltage. If voltage is absent check adaptor voltage at the pin.If no voltage change the adaptor.However if the voltage is presrnt,test voltage of the battery.If below marked level replace battery.if not ,clean battery contact and place into the slot.If after full charge the battery wont last then replace battery.
Sep 28, 2010 | Sony Ericsson XPERIA X1 Smartphone
Does a nintendo ds lite need the battery in to power up on just the adaptor?
The adaptor is only to recharge the battery. If you only use the adaptor without battery, I'm sure nothing will happen. You need the battery in or you can't play. But you can play with both the battery and adaptor in at the same time. It makes your battery recharge + you can play meantime.
May 20, 2010 | Video Game Consoles & Games
My computer will not start. Last I used it I had forgotten to plug it in. It displayed a message about critical low battery and I rushed to plug it in, but it will not re-start. I got another battery...
does it work if u use adaptor ?
did u check if the adaptor is OK ?
1st may be ur adaptor is out !!!
2nd ur batteries are not charged by the adaptor !!
3rd no power in any of ur batteries..!!!
Dec 23, 2009 | Sony VAIO FX340 Notebook
How to charge!!!!!!!!!!!!!
the best way to charge the batteries is to take them out and place them in an external battery charger, this will also avoid any damage to the camera directly
then also check to see output MA of the USB adaptor which would generally be very less and takes very long to charge
for example if the batteries are 2200MAh and the output MA of the USB adaptor or for that matter of even an external adaptor is 200MA then it takes roughly 11 hours to completly charge the batteries
pls rate if this was any help
Jul 03, 2009 | Kodak EasyShare C613 Digital Camera
Dell 600m Computer won't power with adaptor connected
Bad motherboard, unfortunately. Seen it before as a Dell tech.
Jun 29, 2009 | Dell Inspiron 600M Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
Ckeck if your adaptor has power on the connector to laptop.
Might be damaged power cord (to and from the adaptor) or broken adaptor.
While there was power in the battery, it was running, but not charging.
Now the battery is emty and can't be charged because of broken adaptor/cables.
If you find there is no power from the adaptor, bepair it or buy a new one.
Do not try to repair the adaptor by yourself if you are not a technician, it is DANGEROUS !
Either give it to a qualified servicer, or betteer, buy a new one.
Mar 27, 2009 | Computers & Internet
Gateway MT3422 won't charge battery
shutdown the notebook - unplug the a/c adaptor - remove the battery - re-insert the battery - plug-in the a/c adaptor
it can also be a systemboard failure
Mar 21, 2009 | Gateway MT3422 RTL Notebook
Wont power up
the vr\ery first thing what u have to do is that disconnect the ac adaptor and take the battery out of the computer and then press and hold down the power button without the battery and the adaptor for one minute and then connect the ac adaptor and put the battery back in and then try and turn it on and what u can do is that try and turn on the computer only with the battery and then take the battery out and try and turn it on only with the adaptor,and then what u can try is that try with the different adaptor having same configuration,and try and connect the ac adaptor into the different wall outlet....good luck
Jan 28, 2009 | Dell Inspiron 6000 Notebook
Lap top problem
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
