Question about Home
My neighbor was replacing the battery in his smoke alarm and he totally removed the door. It will not close all the way now.
3 Suggested Answers
TeaCii
  • 90 Answers
SOURCE: Smoke alarm keeps bleeping
Here are the steps:
Was this always like this? If not, change the batteries, clean it up. Consult the local fire dept. The help for free.
If that does not work, you will need to get it serviced/repaired.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Posted on Apr 23, 2010
  • 1509 Answers
SOURCE: used the key to unlock door and alarm started
With the drivers window down, and the doors closed. and locked connect the battery and lock and unlock the tailgate with the key, you need to unlock it twice to unlock the doors and turn off the alarm. If the locks are working like thier supposed to the drivers door will be unlocked and opening it won't set off the alarm. the truck should be back to normal. If not disconnect the battery again. Drivers window down. Put the key in the switch and turn the key on to the run position. With all the doors closed connect the battery. connect it good and don't bounce it around. If the battery casbles aren't clean clean them good so it'll connect good. If it still is alarming then the doors switches are likly. Or the door locking motors. You should be able to lock all the doors ( including the hatch) by hand and get the system to reset. Try it all again using a different door to double unlock as a lock switch might be sticking. If the system can't verify that all the doors are closed and locked it won't reset. If you connect the battery wihg the key turned on the system thinks it's already running and appeares to be in the unset mode.
Posted on Dec 16, 2010
HOW DO I REPLACE BATTERY ON FIREX FX1218
BATTERY REPLACEMENT Always turn off power to smoke alarm before replacing battery.
Replace battery at least once a year, or immediately when the low
battery signal sounds (a beep once per minute indicates low bat-
tery). Batteries should be replaced regularly as necessary, even
when the smoke alarm is receiving AC power.
Use only the following batteries as replacements in this smoke alarm: Eveready 216, 522, 1222, Duracell MN 1604, or Ultralife U9VL-J [Alkaline batteries 9Volt] DO NOT USE RECHARGEABLE
BATTERIES.
1. Turn off power to smoke alarm at main service panel.
2. Turn smoke alarm counter-clockwise to detach from mounting plate.
3. Gently pull down smoke alarm. Be careful not to separate wire
connections.
4. Pull out power plug from back of smoke alarm.
5. From back of smoke alarm, lift tab to open battery pocket door.
6. Remove battery from pocket. Disconnect and discard bad battery from battery connector.
7. Connect a fresh, 9-volt battery to connector. The battery will fit
only one way. Be sure battery connector is securely attached to
battery terminals.
8. Place battery into battery pocket.
9. Close battery pocket door. Push down until it snaps into place.
10. Replace connector plug. Connector will "snap" into place.
Gently tug connector to be sure it is attached properly.
11. Reattach smoke alarm to mounting plate by turning smoke
alarm clockwise until it snaps into plate.
12. Turn on power and test smoke alarm using Push-to-Test button
Jan 03, 2018 | Home
Deta fire alarm keeps goimg off and we cant remove It
Replace it. All alarms should be replaced after 10 years. Date is on the base.
How to Reset a Smoke Alarm That Won't Stop - Consumer Reports
https://www.consumerreports.org/...alarms/how-to-reset-a-smoke-alarm-that-wont-sto...
Sep 17, 2016 - Q. My neighbors' smoke alarm went off at 3 a.m. Fortunately, it was a false alarm, ... A. In 2014, 33 percent of false alarms that fire departments ...
Why the **** are my smoke detectors going off? - Home Improvement ...
www.dslreports.com > Forums > Tech / Special Interest > Home Improvement Jul 28, 2007 - 30 posts - ‎20 authors
Hard-wired with battery backup system...keeps going off for about 5 seconds every 15-30 minutes. ... smoke alarm go off with high moister too. .... Our local fire department said one of them was dirty and suggested using the ...
Deta fire alarm Google Search
Nov 18, 2017 | Cars & Trucks
How do I fix a jammed battery compartment in a kidde i12060 smoke detector?
You could try to pry the door loose with a small screwdriver. To be safe, make sure the primary 110V power is turned off before trying to loosen the compartment door.
This is an inexpensive unit, less than $10, and is easily replaced if you can't get the door open.
If you do decide to replace it, you may want to look into a combination unit which monitors smoke and carbon monoxide if you don't have a carbon monoxide detector already in your home.
Aug 26, 2015 | Kidde i12060 Hardwire w/ Front Load...
Replaced the battery and now the door won't close, no matter what I try. I think I broke something?
Possibly. Does the door close with the battery removed? If so the battery is installed incorrectly.
This is an inexpensive unit, less than $10, and is easily replaced if you can't get the door to close.
Mar 22, 2015 | Kidde i12060 Hardwire w/ Front Load...
How do I totally disable 1999 buick alarm system?
Disconnect back up battery and main battery.,
Jul 28, 2014 | Buick LeSabre Cars & Trucks
Used the key to unlock door and alarm started going off. put key in ignition to start, but wouldn't. removed battery cable, do to neighbors, and the alarm keeps sounding. how can I shut it off? just...
Dec 16, 2010 | 1996 Jeep Grand Cherokee
My car arlarm on my 1999 Sebring convertable Has gone off aT 4:00 IN THE MORNING! Much to my neighbors dismay. She heard it before I did, and called. Now it seems the ding sound of the door opening goes...
I have the same problem i have a 98 and my neighbors left notes on my car already hahahahahaha what do i do is there a way to just disconect the alarm at all with out afecting other systems oh pls let me know
Apr 22, 2010 | 1998 Chrysler Sebring
Kidde smoke alarm won't stop chirping . I have replaced the batteries and nothing seems to fix the problem
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
Mar 21, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Replaced 9 v batteries, units still chirping
This is the troubleshooting information from the kddie site. The problem is usually related to an older battery or improperly installed battery. You might also have to do a reset as described below. If battery and cleaning don't work, it might be time for a replacement - short money to keep you and your home safe.
  1. The battery may be loose, or improperly installed.
    Verify that a battery of the recommended type is securely installed. Make sure to use a battery with a use-by date no later than four to five years in the future. Check that the battery is snapped in completely so it cannot be shaken loose. It’s possible that battery connections may not be making good contact with the battery. Disconnecting and re-connecting the battery once or twice will likely fix this condition. On units with a front-load battery, be sure that the battery compartment door is closed completely as well. Loose white neutral wire can cause an echoing chirp. (From one unit to the next)
  2. The smoke alarm sensing chamber may be dirty.
    Dust and insects can collect in the sensing chamber of the alarm. An accumulation of dust in the sensing chamber can cause the unit to chirp. It is good practice to clean the smoke alarm when you change the battery. Static electricity from the ac quick connector attracts dust and can cause false alarms.
    Cleaning smoke alarms:
    To clean your alarm, remove it from the mounting bracket as outlined here. You can clean the interior of your alarm (sensing chamber) by using compressed air or a vacuum cleaner hose and blowing or vacuuming through the openings around the perimeter of the alarm. The outside of the alarm can be wiped with a damp cloth. After cleaning, reinstall your alarm, verify the green LED is on and test your alarm by using the Test Button. If cleaning does not restore the alarm to normal operation, the alarm should be replaced.
  3. Check environmental conditions:
    • Humidity, steam and condensation can cause false alarms. Causes of condensation are:
      • Extreme temperatures changes.
      • High ambient humidity.
      • Unit being installed in an uninsulated electrical box mounted on a ceiling beneath an attic. If this condition exists you’ll want to move the alarm. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check to see if there is a cooling/heating register, a ceiling fan or an open window within 3 feet of the alarm. If there is, move the alarm away from the source of the increased airflow. Click here to see the correct alarm placement in your user’s manual found in our Download Center.
    • Check the temperature of the room. Smoke alarms operate at 40 degrees to 95 degrees Fahrenheit. Carbon monoxide alarms operate at 40 degrees to 100 degrees Fahrenheit.
  4. Reset the alarm.
    Some current model smoke alarms have a processor that retains certain error conditions, such as a weak battery. The error condition should reset when the battery is replaced but sometimes it does not and must be manually reset to clear the error.
    To reset an AC unit with a battery backup:
    Turn off the power to the smoke alarm at the circuit breaker.Remove the smoke alarm from the mounting bracket and disconnect the power. Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reconnect the power and reinstall the battery. The unit will chirp once when the power is restored and should not chirp afterwards.
    To reset a DC only unit:
    Remove the battery. Press and hold the test button for at least 15 seconds. The unit may chirp or alarm for a few seconds before going silent.Reinstall the battery. The unit will chirp when the battery is first connected but should not chirp afterwards.
  5. An electrical condition may be causing the power to the unit to be interrupted.
    If the AC power to the unit is interrupted, the unit will chirp when the power is restored. This could be caused by power surges.
    If the chirping seems to occur at about the same time in the evening or morning, it could be due to a surge created when the power company switches electrical grids to meet demand. Check to see if the chirp (or chirping) occurs when something else in the house is turned on such as an exhaust or attic fan, a heater, etc. If the smoke alarm is connected to a circuit with such a device, the alarm may chirp when the other device is switched on. If this is the case and the device is plugged into a wall outlet, move it to another outlet on a different circuit. If it is a hardwired device, have an electrician investigate it. These conditions can be minimized by installing your alarms on a dedicated circuit in compliance with NFPA requirements.
  6. Replace the alarm.
    If none of these conditions exist and the suggestions don't alleviate the symptom, the alarm should be replaced. Age may be a factor. Smoke and heat alarms should be replaced every 10 years, and carbon monoxide and combination alarms should be replaced every 7 years. Most of our alarms have a 5 year warranty from date of purchase (check your user manual for details). A date code is stamped on the label attached to the back of the unit.
Feb 02, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
My kidde smoke and carbon monoxide alarm keeps beeping and saying low battery and i don't have a manual how do i open it so i can change the battery?
You will need to remove the unit from the ceiling to reveal the battery compartment on the back. It should just need to be rotated counter clockwise a small amount and will then come loose from the bracket. When installing a new battey be sure to press the battery reminder finger down into the battery compartment or the battery door will not close. Call the Kidde (pronounced kid-a) hotline if you have problems 1.800.880.6788
Aug 05, 2009 | Kidde i12040 Hardwire Smoke Alarm with...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
