How to remove bios password unfortunately i forget it
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
You may be able to just remove the bios battery, this will also reset all the settings to default, if this is a pc tower unplug the power open the case and locate it on the motherboard, it will be a watch/button type battery, take it out and make sure you leave it out for a good half hour before replacing it, if this is a laptop doing this may be more difficult unless it is located under the laptop battery with access to it.
other than this you will likely need a usb memory stick and install a password cracker there will be info on youtube on how to do this
Posted on Dec 31, 2016
  • 3 Answers
SOURCE: Forget my bios password
i have laptop hp pavilion dv 2000 and i forget password bios so i cant open the setup to boot sequence .please solutte this problem
Posted on Mar 12, 2008
SOURCE: forget bios password
hi ,
I had same problem, just remove plastic trim ( the one with the switches to power on etc etc ) and you will see a micro dipswitch. It should have all 4 switches to 0, move switch 1 to position 1 power laptop and password should be removed. Turn laptop off move switch 1 back to posiotion 0 and replace the plastic trim. It worked for me on an ACer Aspire 3610.
good look
Posted on Jun 03, 2008
  • 66 Answers
SOURCE: I Forget the BIOS setup password
When you start your computer, tap F2 key to enter the BIOS setup. In the security menu is the area for removing/resetting BIOS password.
Posted on Feb 18, 2009
  • 74 Answers
SOURCE: remove bios password
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service:
Posted on Dec 16, 2009
  • 17 Answers
SOURCE: acer aspire 2920 bios password removing
The password to by-pass bios password are these, hope they will hope you, once you enter BIOS using these passwords you can reset it to normal
Phoenix Backdoor BIOS Passwords:
  • BIOS
  • CMOS
  • phoenix
Posted on Mar 22, 2010
Toshiba Laptop Satellite M30-742 Power On Password Reset????
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore...
You can download it here:
CmosPwd - Cmos password recovery tools
Jun 27, 2012 | Toshiba Satellite Computers & Internet
How to Bypass BIOS Passwords
If you are unfortunate enough to set a password for your BIOS password for PC and forgot it, chances are you may need to send it back to the manufacturer. Not to worry yet, you still can try out some tips and tricks to bypass or unlock the BIOS password:
BIOS passwords can add an extra layer of security for desktop and laptop computers. They are used to either prevent a user from changing the BIOS settings or to prevent the PC from booting without a password. Unfortunately, BIOS passwords can also be a liability if a user forgets their password, or changes the password to intentionally lock out the corporate IT department. Sending the unit back to the manufacturer to have the BIOS reset can be expensive and is usually not covered in the warranty. Never fear, all is not lost. There are a few known backdoors and other tricks of the trade that can be used to bypass or reset the BIOS password on most systems.
on Jul 14, 2010 | Computers & Internet
How to clear bios password when i forget it-my laptop is cq61 132tu
I work for a computer company and a graduate of Computer Technician course, so I know computers very well. Regarding your concern, unfortunately BIOS passwords cannot be removed and it can only be reset if you know the current BIOS password. The solution to this will be a motherboard replacement. Even setting the computer back to it's factory default is impossible because it will keep on asking you for the BIOS password. I'm sorry for the situation you're at right now and thank you for visiting FixYa!
Apr 16, 2011 | Computers & Internet
I forgot my password and when i tried to reset my password my laptop is asking for a removable reset disk. How am I gonna make a removable disk?
Need to download pc lo-gin and create under image burning option, from any nerro,
boot from cd ,
start pc >press F10/F 2/Dell setup bios for boot pioroty.
Insert cd in your cd tray and it will automatically reset password ,
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya
Jan 26, 2011 | Computers & Internet
In my laptop lenovo g550 , i forget bios supervisior password, so kindly tell me how willremove biose supervisior password. i can open my laptop , i have remove bios battery but same issue,
Are you the one who set up the BIOS password? If not, unfortunately, there's no way for us to retrieved the password. The only way you can reset the password to default settings is to reseat the CMOS battery on the motherboard, its a circular thing that looks like a battery of a watch,sometimes a pin hold it, just detached it then wait for at least 30 minutes then connect it back again,
Note: Before you reseat the CMOS battery,make sure that everything is unplugged on the computer, like AC adapter,battery and all external devices...
Hope this will help...Your response is very much appreciated...
Jan 22, 2011 | Computers & Internet
12609 bios password
Unfortunately the best way to reset bios password is to open up the case and remove the bios battery for a couple of minutes. In the meantime press the power switch in order for the capasitors to discharge. After a while insert the battery and close the case. Don't forget at the first start up to load bios defaults because the settings you may have will not be the defaults for sure.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Jul 21, 2010 | Acer Computers & Internet
Acer aspire 2920 bios password removing
  • BIOS
  • CMOS
  • phoenix
Mar 18, 2010 | Acer Aspire 4720 Notebook
How can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
how can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
May 04, 2009 | HP OmniBook 500 Notebook
on the underside you can take off a panel with a screw driver by unscrewing the philips head screw, and from there, you should find a small, flat, round looking battery, it may be in a yellow or black coating. you have to disconnect this, and then reconnect it. this will reset your bios.
Jan 06, 2008 | Acer Aspire 5100 Notebook
Password problem
for bios password remove bios cell or clear bios by jumper setting changing.
for logon password start pc with safe mode.and remove the password
Aug 21, 2007 | HP OmniBook500 250MB Zip Drive Module...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
