Nese sitpo hakckear este vnumero de telefono su textos el numero es 8453418143
    Top Expert:
  • Televison & ... Master
  • 73,635 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on Dec 31, 2016
CONTROL REMOTO NUEVO NO PUEDO PROGRAMARLO AL RECIBIDOR DISH.
Hola Jose, mi nombre es Kimberly y formo parte del departamento Social Media de DISH. Es my placer asistirle. Para que el control funcione, debera de programarlo al receptor. Para programar el control de DISH Network a su recibidor puede seguir los siguientes pasos: primero debe de accesar la pantalla de System Info esto lo puede lograr con tan solo oprimir el boton que dice System Info enfrente de su recibidor. Una vez este la pantalla de System Info tome su control y oprima el boton se Satellite por 5 segundos hasta que todos los demas botones se iluminen en rojo una vez esto suceda oprima el numero 8 seguido por el signo de numero (#) y despues boton de Record 3 veces. El control deberia de funcionar, puede intentar su funcion oprimiendo el boton de Cancel esto deberia de llevarlo de regreso a su programacion. Puede usar este link que tambien le puede servir mucho en como arreglar su control y los pasos seguir http://www.dishnetwork.com/SupportSection/remote-control Si tiene preguntas adicionales sientase libre de contactarme a: kimberly.escobar@dish.com
Kimberly Escobar
Social Media Representative
DISH L.L.C
Dec 10, 2013 | DISH Network IR Remote Control
Desconecte una caja doble de dish y ahora uno de los televisores no funciona
Hola Jorge, disculpe la demora en responderle, quizas en este momento ya no necesite la respuesta para este problema pero me gustaria proveerle los detalles de todas maneras por si en futuro necesita ayuda esto le pueda ayudar. Este problema lo puede ocasionar distintas razones. El primer paso a tomar es: Por favor verifique que luces estan prendidas enfrente de su receptor. Bajo donde dice MODE la luz debe de estar en DUAL (2 cajitas) si esta en SINGLE, abra a puerta enfrente del receptor, oprima el boton que dice 'Mode' para poner el receptor en DUAL. Si este no es el proble may esto no lo arregla necesito que en el cuarto del televisor numero 2 (donde NO esta el receptor) usando el control que vino con la TV cuando la compro que ponga la Tv en el canal 60 si tiene una imagen necesito que agarre su control de DISH y en el control oprima el boton de SAT (el cual se encuentra en la parte de arriba a mano izquierda) una vez haga esto, trate cambiar canales. Si esto no funciona, otra vez con el control original de la Tv trate de poner la Tv en el canal 73. Si le sale una imagen, agarre el contriol de DISH, oprima SAT y trate de cambiar canales.
Si lo recien explicado no le funciona, valla a la TV 1 otra vez. Con el control 1 en mano Oprima Menu y una vez tenga el "Menu Principal" en la pantalla Oprima el numero 6, espero dos segundos y oprima el numero 1, espero otra vez dos segundos y oprima el numero 5. Este proceso lo lleva a una pantalla llamada 'Modulator Set Up' En esta pantalla donde dice 'TV 2 OUT' bajo 'Channel' que numero de canal tiene? 73 o 60? Basado en el numero valla al cuarto de TV 2 y usando el control que le pertenece a la Marca de TV (no el control de DISH) ponga la Tv en ese canal. Esto tambien debe de resolver el problema. Si necesita asistencia con su servicio de DISH sientase libre de contactarme a: kimberly.escobar@dish.com
Kimberly.Escobar
DISH L.L.C
Sep 22, 2013 | DISH Network 322 DTV Receiver
Mi televisor es marca LG y quisiera poderlo apagar y prender con el control del dish network quisiera y me pudieran alludar?
Luis, mi nombre es Kimberly y formo parte del departamento Social Media con DISH. Es un placer poder asistirle. para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales sientase libre de contactarme directamente a: kimberly.escobar@dish.com
Kimberly.Escobar
DISH L.L.C
Aug 24, 2013 | Televison & Video
Como puedo programar el control de la Caja de dish network para que apague mi tv lg
Kimberly.Escobar
DISH L.L.C
Yo mande mas de 10 mensaje de numero celular 584123362473 y 04125516627 y no me an dado ningun credito, por ejemplo:gracias, facebook le cobro 5.80vef a su cuenta de telefono. codigo...
compre token por zong mande 3 mensajes solicitando 121 token por zong me cobraron los msj y nunca me llego el codigo ni los tokens mi numero es 04268104327 de venezuela me mandaronun mensaje de zong discurpe por la compra contactar a support.vzzong.com y no consigo la pagina :S
Aug 19, 2011 | zong.com
MI TELEFONO REQUIERE ALGO QUE DICE EN LA PANTALLA "NIP" QUE HAGO ??
Hola, creo que a lo que se refiere NIP es Numero de Identificacion Personal, es mas conocido por su abreviatura en Ingles PIN, puede ser el PIN del telefono o del SIM card (llamado comunmente CHIP), si es el PIN del SIM card usualmente el operador pone cuatro ceros, si es el del telefono habria que buscar en el manual del mismo cual es de fabrica (default).
Mar 02, 2011 | Computers & Internet
Hola el problema es que son dos telefonos registrados en una base pero el 2 que seria el movil no funciona no da linea suena como si estuviera ocupado,ya lo intente con el manual y nada ha es nuevo gracias...
Hola, el procedimiento sujerido del fabricante en este caso es el siguiente:
  1. Retire y vuelva a colocar las baterias
    del terminal.
  2. Intentelo de nuevo desconectando la
    alimentacion de la base y volviendola a
    conectar y siga el procedimiento de
    registro de un telefono.
Registro de un auricular.
  1. Inserte la bateria para encender el
    auricular. En la pantalla LCD
    aparecera "PULS TECLA OK
    PARA REGISTAR".
  2. Pulse pantalla LCD aparecera "PULSE
    PAGE DURANTE 5 SEGS".
    Antes de que transcurran cinco
    minutos, pulse la tecla de
    localizacion (PAGE) que se encuentra en la
    estacion base para iniciar el proceso
    de registro.
  3. Si el registro se realiza con exito, el
    auricular volvera al modo en espera.
    Si el registro no se realiza
    correctamente, en la pantalla LCD
    aparecera "PULS TECLA OK PARA
    REGISTAR". Repita el proceso de
    nuevo.
Feb 28, 2011 | Philips CD1503B/17 Phone
No se como progamar mi control remoto de Dish Network por que mi televicion es marca Emerson pero tiene VHS incluido?
Hola mi nombre es Kimberly Escobar y soy representante de DISH Network servicio al cliente. Tengo entendido que necesita ayuda programando su control de DISH Network con su televicion Emerson, seria mi placer asistirle proveendo la informacion necesaria. Para programar el control con su televicion hay un cierto codigo que se integra al control, permitiendole controlar ciertas funciones en la T.V. No podemos prometerle que pueda funcionar completamente el VHS. Uno de los codigos que posiblemente se integren al control para trabajar con su T.V seria el numero 632, El paso a seguir es el siguiente: oprima el buton transparente en la parte de arriva del control que diga T.V, cuando vea que los otros botones se prendan em rojo ingrese el numero 632 seguido por el signo de numero (#), el boton de T.V debe de iluminarce 3 veces. Una vez acabe con este procedimiento puede intentar usar el control con su T.V. Si tiene preguntas adicionales o necesita ayuda puede encontrar nuestra pagina web muy importante http://www.dishnetwork.com/SupportSection/power-scan-instructions tambien puede contactarnos directamente al 1800-333-DISH muchas gracias y espero esto le sea de ayuda.
Jan 29, 2011 | DISH Network IR Remote Control
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
