Question about Pool & Spa
Dream maker spa light keeps going on and off. any ideas?
  • 366 Answers
SOURCE: what size shaft seal is in a dream maker eclipse
Your spa should have the aquaflo pump which uses a PS-200 seal.moz-screenshot-1.png
Posted on Oct 27, 2009
SOURCE: how do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
If you don't have the tool you can order one from Dream Maker.
Posted on Nov 04, 2009
  • 12744 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Posted on Apr 01, 2010
SOURCE: I have a Dream Maker x-spa Dition 4 person spa. i
hi i am having the same problem have you managed to fix it and how any help would be much appreciated thanks joe
Posted on Aug 06, 2010
My dream maker big eze hot tub the jet light on the upper control panel just keeps blinking what does that mean
Are the jets coming on when you press the button?
Try unplug the control from the board and plug it back in.
Dec 01, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker x-500 5 person developed cracks in the shell of the 2 corner seats, nearest the access panel. It appears the seat supports molded to the base of the spa are pushing the seat bottoms upwards,...
If it's loosing water this should be a structure warranty. I have two of these and had to drain the spa and shine a light in the spa and take pictures from underneath. Then the light will show off the cracks well. If your the original owner just keep at Dream maker, they should give you a new one.
Dec 11, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jun 25, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a dream maker and my heater will not turn on. I had this problem once before when I drained it. However I cannot get the SN error code to go away. Any help would be great
Dream Makers do not have traditonal heaters. You may have an airlock. Look for a plug on top of the pump or some part of the plumbing, loosen to let the air out.
Mar 05, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
My dream maker hot tub keeps needing to be reset at the plug i have to keep resetting it all the time is there another fuse or something i can do
Your heating element is going to ground and 'leaking' current. The GFCI is picking it up and you will need a new element.
Aug 19, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
49 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
