Question about Haier Televison & Video
My haier LCD displays picture at the ATV but no pictures at the says invalid format even though I get sound
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
Posted on Apr 30, 2008
SOURCE: Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
Posted on Jul 11, 2008
  • 58 Answers
SOURCE: invalid format
the comp is set to an unsupported screen res. set it to 640x480 and try again.
Posted on Dec 06, 2008
SOURCE: i have a toshiba 32hl67u lcd tv
I had same thing happen recently on same model. Turned it on one night, light came on in screen, briefly saw info bar at top, then nothing. Cannot get picture, volume or menu. Each time I turn off and turn on the same thing.
Any solution to this appreciated.
Posted on Jan 02, 2009
  • 58 Answers
Use the power button on the front of the console, to put it in standby mode (red light on).
Then press and hold the power button until you hear two beeps.
This should fixya.... :)
please rate this answer!....
Posted on Sep 25, 2009
Testimonial: "thankyou, that actually worked, i did not know this could be fixed this way"
We bought our TV in Australia but are now living in new Zealand our TV comes up with invalid format to have tried returning but we get sound no picture. Will this mean it won't go in new Zealand.
The TV may be too old even if it is a digital TV set. NZ terrestrial DTV broadcasts in MPEG-4 format, and a lot of Aussie digital TVs won't receive this. A Freeview digital set top box should solve this problem, and be cheap.
Dec 06, 2016 | Miscellaneous
Tv has picture, no sound, just popping/clicking
Probably the internal power supply has failed. It can happen even though your TV was stored and covered.
Dec 06, 2013 | Haier HL32R 32 in. LCD TV
Get sound and "invalid format" message displayed instead of picture
Could have still been hit by a surge. Take the back off of the TV and look at the main board were you connect your HDMI. See if it is scorched or components that blackened. Also check your DVD player on another set. Your DVD player could be the problem.
Apr 11, 2012 | LG Televison & Video
I have a Mintek DTV-323 32" LCD TV. When I power
You need to replace your main board. This is a heat issue on your micro and cannot be fixed at component level.
Apr 18, 2011 | Mintek DTV-323 32 in. LCD TV/DVD Combo
Brand new haier hl32r1a has thin red line running down the right side of the picture close to the edge..its just mildly annoying...can we get rid of it somehow?
Get the unit replaced if it is brand new. This type of problem is caused by a fault in the LCD panel, not something you can repair yourself. One of the driver chips that runs the display has a shorted output line which creates the red line on the screen. Even though the problem is mildly annoying now it may get worse as time goes on and your warranty runs out.
Corporate Computer
Apr 18, 2010 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Invalid format displays on screen
hello try changing the picture ratio...what i mean is try 16.9 widescreen or 4.3 ledder box the tv is tryn to produce a pic bigger or smaller than what you have keep tryn different picture ratio's
May 20, 2009 | LG 26LG30 26 in. LCD TV
Television picture issues...
I had the same problem when I accidently hit the remote. If you are hooked up to cable make sure INPUT is on the correct setting -- AV, S-Video, YPbPr1, YPbPr2, VGA, HDMI1, HDMI2, ATV & DTV (see button on TV or remote). Hope this solves your problem.
Jul 27, 2008 | Astar LTV-3201 32 in. LCD Television
The ;quick answer is YES, you will need a converter box to receive digital broadcasts. This set has only an analog tuner built-in. That is why it is HDTV "ready" (ready for you to add a tuner).
As for HDTV vs EDTV it is a matter of resolution. Your set is capable of EDTV resolution, which is better than SDTV (standard definition TV) but not quite as good as HDTV. With a digital tuner you will be able to view all digital programming, even HD, and it will look excellent, though not quite as sharp as a set with higher definition.
Feb 14, 2008 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
Mintek dtv 323-d
my 323 lcd has power sound and plays dvds but i cannot see a picture
Jan 21, 2008 | Mintek DTV-323 32 in. LCD TV/DVD Combo
Televison & Video Logo
32 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
