Question about Bosch WFMC 3200 Front Load Washer
Spin too hard and knock !
Hello, on my old (15 years) Bosch washer, the spin sometimes seems too "strong", all knocks and it finished to brake both the driving belt and the drain hose (hole in it) !
This machine was supposed to detect any "off balance" (it worked like this since now) :
-> Could it be this detection system that is out of order ?
-> Or could it be the 2 "shock absorbers" that have become loose and so to be changed ?
Thanks for a rapid answer if possible (the dirty cloth pile is growing !)
  • Anonymous Feb 02, 2008
    My Bosch WFMC 3200 went out of balance when a load of towels because too heavy. The machine nearly went through the wall and it did not shut off. Since that time even small evenly dispersed loads cause the machine to jump around and sound scary when in the spin cycle. Is there something that I can do myself without having to call in a service tech? Thanks, Henry
  • 249 Answers
Bearings gone in drum replace machine
Posted on Nov 25, 2007
My machine has been very noisy for a few weeks and today I put on a cycle and the drum didn't spin at all. Any ideas, ny machine is 10 years old!!
Noise could be worn drum bearings in which case pulley would wobble knocking off belt, hence no spin......
Mar 27, 2011 | Bosch Washing Machines
Agitator will not spin easily from pully below or
transmission out buy new washer cost to great to repair 15 year old washer
Feb 03, 2010 | Maytag LAT3600A Top Load Washer
Kenmore HE3 washer started knocking and shaking during spin.
indicates that the tub support rods have failed at the air dampners
the fix is new rods from the service agent spares and a re levelling if the tub ,not the machine
Nov 20, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Knocking sound in the spin cycle off balance.
The motor switch that is mounted on the motor may need replacing. The knocking could mean that the "run" winding is cutting off momentarily, and running on the "start" winding of the motor. I dont know about a 22 year old model, but in most "near modern" machines, the switch has a plastic actuator that is pushed when the motor obtains near-run speed, that plastic may be worn or the actuator part on the motor may be at fault. If you replace the motor, you usually get this switch as part of the deal.
Feb 05, 2009 | Maytag Washing Machines
Top loading washer will not spin
ngfam1 At your service!
Sometimes this can happen when the connector from the transmission to the drive of the agitator is broken and needs to be replaced.Similar to the drive shaft of a rear wheel drive v-8 car!
Could have sounded like a knock,knock,knock or klack, klack,klack before it happened.
OR sometimes there is no warning at all.
How old is it?
If its 9 years old or more and it's the transmission or any other expensive repair, I would then advice not to put good money into bad and cut your loses. The new machines are so energy inefficient that they can pay for them selves in only a few years!
Less water, gas, electricity, and detergent!!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 30, 2008 | Frigidaire Washing Machines
Loud knocking noise at end of spin cycle
Have you checked the wire harness ,because the tapping of just 2 wires hitting the cabinet is overlooked alot.The noise just 2 wires makes simulates a hammer knocking inside.If the problem isn't escalating than check to see if your tub support arms are all tight.There are 12 of them.
Jun 12, 2008 | Washing Machines
Noisy spin dryer
make sure the washer is level.there's locking nut for each legs sometimes thy become loose and the unit becomes unlevelled after a while. Level the unit side to side and front to back and relock the nuts by tightning it against the bottom frame. If thats not the problem,run it on spin only with no load and see if it would do the same if it does'nt then your problem could just be improper loading. make sure you have enough load to cover the drum when it spins.Other wise you may have shock/spring problem but very unlikely
Jul 22, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
232 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
