Question about MAG Optics
Ps410 bolt will not go up or down allso mag willnot rowtate
Why won't the bolt close all the way down
Check the breach plug, bolt retaining screw and scope mount screws if they are present. You may need to use a plastic mallet and gun oil like clp
Sep 29, 2015 | Remington Model 700 BDL LSS Bolt Action...
Serial numbers winchester: bolt action #39163A, barreled by Griffith & Howe.
Griffin and Howe were out of business before the 300 win mag was introduced.
Sep 24, 2013 | Remington Model 700 BDL LSS Bolt Action...
I am trying to connect alpine cd changer to 1999 isuzu factory stereo.
It willnot work, You have to have the same brand of changer as your (Deck) Allso the deck has to be equiped that you can hook up a changer to it,
Oct 24, 2012 | Pie ISU/98-ECL 98-01 Honda/Isuzu/Acura...
Receiver suddenly turns off
If you have the vollume control set around 40, End watching a movie if there is a loud burst in vollume,It is causeing the reciever to run over it,s wattage rateing. End over heating,When it,s shuts down, It went into what is called the protection mode.Keep it at a lower vollume then it willnot do that.Allso what can cause it to do that, If you have your output leval control on your sub turn right up.
Oct 17, 2012 | Yamaha RX-V665 Receiver
On my sks rifle when stalling clip have to hold bolt back to install clip
Are you talking about a full magazine? You have to get the bolt out of the way because it is too tight? Take out 1 round and see what happens. Does it do it to an empty mag? You are not talking about a stripper clip are you? You know they don't come with magazines, the 30 rnd mags you get that are detachable have been modified some how. And they don't go in easy. Not like an AK, Let me know.
Apr 20, 2010 | SKS Rifle High-profile See-thru Scope...
I'm trying to play a game in the PS2 but wont work and it cliks.
disk drive is broken. did you try laying it down to play? if you did and still the same its time for a new disk drive. sorry hope this helps. they can show how to fix it on youtube.
Apr 17, 2010 | Sony PlayStation 2 Slimline Console
Wont stay running
if diesel most probably air in fuel system,first check all fuel hoses for tightness ,if you can twist any hoses by finger pressure tighten.allso replace any damaged fuel lines ,check all bolts on the injectors for loose play ,allso check fuel tank breather for blockage does it improve with fuel cap cracked not drive on the road like this !!.Finaly check your lift pump which fail quite often.Have you checked your fuel filter for dirt if black or dark replace.
Mar 02, 2010 | 1984 Toyota Pickup Deluxe
Cd changer
don't e-mail me again YOU ARE to expensive for the time spent finding the solution
Jul 22, 2009 | Sony Car Audio & Video
The Bolt will not stay back after last shell is fired from mag.
Try putting the original magazine back in.The tapco mag probably does not have the vertical extension that holds the bolt open.Compare the two mags side by side.Good Luck
Apr 07, 2009 | SKS Rifle High-profile See-thru Scope...
I need to replace the crank sensor on my 1992 chevy lumina the only problem is i cannot get the old crank sensor off
  • Disconnect the wiring harness.
  • Unbolt the sensor mounting bolt.
Jan 31, 2009 | 1992 Chevrolet Lumina
Optics Logo
27 people viewed this question
Top MAG Optics Experts
David Payne
David Payne
Are you a MAG Optic Expert? Answer questions, earn points and help others
