Question about Garden
Plow goes left to right goes up but not down - Garden
  • 104 Answers
SOURCE: snow plow wont turn right
To turn Left you need two cylenders. I think you only have one. Any one cylender will have three wires and a ground. The ground is always connected to the vehicle ground. The other two to the Single pole double throw switch. TOne wire and a ground runs the pump one way, the other wire and the ground runs the pump the opposit direction. For left and right you must have a similar pump, motor and wiring.
Posted on Feb 07, 2009
  • 832 Answers
SOURCE: western snow plow when you try to angle to right
This is a control valve problem. From you comment, it is
clear that the control valve flows to one direction only.
Please check the control valve of the snow plow that
execute the angle to right or angle to left. Also check
the pipelines before and after the valve. It must have a
free flow of the fluid.
Posted on Dec 02, 2009
  • 114 Answers
SOURCE: I have a meyer e47 snow plow and when i touch the
I would check the hand control box it sounds to me like an electrical problem, if you know a dealer, plug in a new control box, this should narrow it down.
Posted on Jan 13, 2010
SOURCE: fisher minute mount goes up and left and locks up
check your connections, especially the main power plug in, i have used a small "c" clamp over the connection to aid in the same problem
Posted on Nov 13, 2010
  • 39252 Answers
SOURCE: I have a 8ft Fisher storm guard plow on my dodge
Duplicate
Posted on Nov 29, 2012
Western plow will not go left
There is a hydraulic block/valve. Replace it.
Jan 03, 2017 | Cars & Trucks
I have a minute mount plow, when I try to use it only goes to left and right side but doesn't go up, when I try to lift the plow goes to the right. What can I do
2002 Fisher Minute Mount Inst-Act Wont Angle [Archive] - PlowSite ...
www.plowsite.com > ... > Truck & Equipment Repair
Nov 17, 2011 - 90 posts - ‎9 authors
My plow went up it was jerking and did it in steps , but , it got there . Now , it onlyjerks when i try to angle it right or left or up . I filled the fluid ... Drop it and if it doesn'traise you can just use a jack and shorten the transport chain to hold it. .... I do havecontinuity on the plow side for all 3 wires going to the plug . Hooking Up A Fisher Minute Mount 2 In Under 1 ...
Feb 1, 2011
Plow Wont Angle
Oct 19, 2010
What's wrong with my plow?
Jan 9, 2003
Looking For Minute Mount Tips
Feb 13, 2002
More results from www.plowsite.com
Ultramount Intermittent Angle Problem - Snow Plow Forum - L
Dec 27, 2015 | Cars & Trucks
Meyers home snowplow goes up n down no problem.angle right it inches its way to the right.angle left motor runs no movement. any thoughts
It sounds like a faulty valve. Some valves use O-rings to seal between ports and they may have failed. I would check the lines for trapped air first.
Oct 25, 2015 | Meyer Home Plow Home Plow by Meyer...
My fisher minuteman 2 plow will go up and left and right but will not go down
Most of those systems don't have a driven retraction on the piston. It is gravity feed back. There is a valve that is sticking or out of adjustment. http://library.fisherplows.com/?cat=38
Jan 24, 2015 | Cars & Trucks
I have a fisher minuteman plow it will go up, left and right but will not go down what is wrong with my plow
If you have a Minit Mount two it's probably the valve sticking. It's electronically controlled so if it clicks, then the solenoid is working and the shuttle in the valve is stuck. Can be disassembled and cleaned. New ones are best but pricey.
I have a fisher minute mount an older model with fixed controls. plow goes up and down but does not go left or right, sometimes with the control set for left or right it starts to go up ? where to sta
check the wiring connections on the plow solenoids to be sure they are correct, the second step is check the controller box, using a continuity check via multimeter set for DC voltage. I have an old western plow that had similar symptoms, and was the controller box.
Oct 19, 2014 | Cars & Trucks
Fisher minute mount plow
does the pressure release close to raise the plow?
Jan 05, 2014 | Dodge Cars & Trucks
Meyers snow plow doesent move left to right
i am thinking the celanoids went bad or a bad ground
Feb 28, 2009 | RTO Michicraft L-13 Canoe By Meyers
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
