Question about Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system
Panasonic sc-bt200 home cinema system,no power coming from green connector on box
  • 3 Answers
SOURCE: sc-ht500 system cable
You cannot wire this system separately, since it is very difficult to separate the power cables from the others which carry the audio parts.if in any case , lets suppose, you could wire the dvd player separetely, you will have no audio since all the audio frequencies are transfered in this cable to the sub woofer and from there to the satellite speakers.
It would be useless to wire it even if we could as there would never be any audio, only video, no matter what disc you use as the only way the audio is comming is throught this system cable to the subwoofer. Actually its the worst idea to implement in a home cinema system, but well, this is old panasonic.. :)
Posted on Dec 07, 2007
SOURCE: No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Posted on Jan 04, 2009
  • 8546 Answers
SOURCE: Panasonic SC-PT460 - Little black box covers half of screen
Can you describe the 'box'? Is it the top half, bottom half, a little of either? What kind of TV do you have?
I suspect you might be noticing the aspect ratio of the various source programs being presented differently on a wide screen than you are used to. DVD programs come in a variety of aspect ratios. Normal TV is 4x3, that is, 4 units wide versus 3 units tall. Wide screens are more like 16x9, so a 4x3 image presented properly on a wide sceen would have black vertical bars on both sides. That is normal.
Some people are offended by the black bars and TV's are unfortunately designed to allow gross modification of the image to fill the space. That is akin to taking a photo of yourself and stretching it to fit an improper frame. That probably wouldn't be very flattering to you and certainly wouldn't be accurate. Which is more important - the picture or the frame?
Posted on Apr 08, 2009
  • 6831 Answers
SOURCE: Repeated F61 fault code on Panasonic Home cinema
F 61 error means the failure of FAN
most probably dust in the fan made it to stop working so clean the dust and connect the fan to an external supply of 12v(using red and black wire) for 5 minutes and reconnect it to the unit otherwise replace the fan with new one.
Surely this will solve the problem.
Kind regards
Posted on Dec 12, 2009
Testimonial: "Sounds most probable, so have just finished dusting it and will let you know outcome, many thanks. H"
SOURCE: home cinema panasonic sc-bt100 error code f61 what
I have same F61 issue, purchased a new fan fitted it today, and I have the same error code??
Posted on Nov 05, 2012
Beim Firmware Update stopt das System bei UPD5/5 - keine weitere Reaktion ???
the firmware update for sc-bt200 & sa-bt200 takes approx 10 mins. the box will display UPD5/5 - this process takes about 10-15 minutes, the box will switch off automatically. Leave for 30 seconds, and power on manually with your remote control - the screen will display - "firwmware update completed.".
Feb 05, 2011 | Panasonic SC-BT200 Home Theater Systems....
I bought a panasonic home theater (open box). the only problem was that it was missing the speaker cables. panasonic wants $166 for the cables! any place elst that would have them or the plastic...
According to the manual the speaker cables are as follows...
1 Speaker cable (center)
[REEX0858-L (green)]
2 Speaker cables (surround)
[REEX0860E-L (blue)]
[REEX0868E-L (gray)]
2 Speaker cables (surround back)
[REE1488 (brown)]
[REE1489 (tan)]
The only things that makes them unique are the unique molded connectors. Hardly $166 worth. You could buy a 100' roll of 18-gauge speaker wire or lamp cord and 5 molex connectors at Radio Shack for a lot less.
If you took the base unit in I'm sure they could help you find a compatible connector and pins.
Jan 25, 2011 | Panasonic SC-BT200 Home Theater Systems....
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
Just want to know difference between Panasonic SA BT200 and SC systems..
from what I can see, the number for the whole system is sc-bt200, while the main unit alone (the bluray player itself) is sa-bt200. The system comes with speakers which all have their own numbers too.
Oct 17, 2010 | Televison & Video
Google for "Panasonic SC-BT200 Region Free
Also see
Some Blu-Ray players will need a hardware mod to be region free.
Feb 05, 2010 | Panasonic SC-BT200 Home Theater Systems....
Panasonic SC-BT200 Home Theater Systems. Single-disc 1000W Blu-ray Disc home theater system Logo
46 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
