Question about Woods Hardware & Accessories
How do I program a Woods model#TH2003 - 7 day - 2 channel appliance timer
I need a phone number to contact woods timer to get help programming one of their timers. Model 50029
Woods 50029 Indoor 7-Day Astronomical Timer ... - eBay
www.ebay.com > ... > See more Woods 50029 Indoor 7-day Astronomical Timer Pr...
Rating: 5 - ‎1 review
Or customize programming options turn lights on/off at sunset, sunrise or ... eBay item number: ...Woods 50029 Indoor 7-Day Astronomical Timer, Programmable, 2-Outlet Grounded ... The Woodsbrand of timers with sun tracking technology can automatically ... If you have immediate questions about application, installation,
Mar 22, 2017 | Woods Hardware & Accessories
Is it possible to utilize the different outlets at different times?
Usually a wall timer is single channel ... even if it has two outlets... so there is only one program that controls the timing.
If you want two separate circuits, then you need a 2-channel timer... they used to offer some 2-channel models but I cannot find them any more.
Alternative would be two timers.
Or two bar timers will fit on same outlet (except bar timers are usually 24 hour and not 7-day)
http://waterheatertimer.org/Woods-timers-and-manuals.html#bar
Woods timers and manuals
Feb 17, 2016 | Hardware & Accessories
Utilitech 2 outlet timer - 0155671
No.
Each outlet has same on-off programming.
Utilitec does not make 2-channel timer.... and neither does any other consumer timer company... unless you buy a box timer like Intermatic ET 1100 or 1800 series etc 2-4-6-8-12 channel timers.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET-series
To have 2 different programs from same outlet, then buy 2 bar timers that both fit same outlet, and then program each to suit need.
Many bar timers are 24-hour instead of 7-day.
Gene
h
Sep 22, 2013 | Hardware & Accessories
I was wondering if the dual outlets can be program individually? For example, both start a 6am but one end at 8pm and the other one at 10pm. Thanks
No. Woods does not make 2-channel timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#digital
Nor is this feature available through Intermatic wall timers, GE wall timers, Leviton, Swilight, UPM, Tork, Westinghouse, Westek, Utilitec, maplin, Stanley, Brinks, Timex, Kichler, Hagar, First Alert, sylvania, Aube, Honeywell, coleman, HPM, etc etc.
However, you can buy narrow timers like Westek TE22, also similar sold by Brinks... and 2 different timers can plug into same duplex outlet... letting you control 2 different loads from same outlet... by using two timers: usually this type timer is sold as 2-pack
http://waterheatertimer.org/Woods-timers-and-manuals.html#Westek
There are also box timers, like Intermatic ET series, that can be programmed for 2-channel operation where same timer controls two different loads, each with different weekly or daily schedule ... Intermatic PE153 offers 3-chanels, and there is one timer, ET90000 that can be programmed for 40+ channels with 4000 set points and 365 day calendar for each channel etc
Tork also offers multi-channel box timers.
Gene.
Aug 04, 2013 | Woods Hardware & Accessories
I have a Westek indoor digital timer, i have a nano tank with 2 lights (moonlight, daylight). I"ve tried setting the timer for 7 days with each light on at different times, it just won't work.Though...
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Woods-timers-and-manuals.html#TE05W
You want to control each light with different programming?
Westek TE05 timer is single-channel timer, so different lights cannot be controlled by different programs.
You need a two-channel timer so each light can come on at different times.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Zilla timers are two-channel timers: yellow outlets for daytime, and blue outlets for nighttime.
Mar 28, 2011 | RTO Amertac TEO5W Decorative Indoor Weekly...
How does this timer work? I lost pkg with info.
I believe the First Alert timer is same as GE 15151 vacation timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#vacation
If this is not your timer, then add a comment.
Also look at Woods timers on link below to help identify timer.
A vacation timer turns on-and-off randomly to give the appearance that somebody is home
This timer cannot be set for daily on-off schedule.
Rotate dial until current day and time line up with arrowhead located on inner dial.
The timer will turn on-off according to preset schedule
GE markets a number of timers for daily repeat programming:
When buying a timer, note that some are for 2-prong plugs and some for 3-prong plugs
http://www.amazon.com/dp/B0015GKI96/?tag=picc-20
http://www.amazon.com/dp/B002HEY300/?tag=picc-20
Woods makes daily timers and a weekly timer
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
http://www.amazon.com/Woods-59202-Vacation-Security-Appliance/dp/B001Q9EFT6
Dec 19, 2010 | First Alert Tm261 7Day Vacation Timer
How do I program Woods digital timer 59203?
Link shows all Woods timers and manuals
If instructions below do not match your timer, look through timers on Woods page to identify, and then add a comment.
Manual for 59203
http://waterheatertimer.org/pdf/Woods-59203.pdf
Instructions below are for Woods 59203 & GE 59203 plug-in programmable timer with 2-prong polarized outlet:
Plug timer in until battery is charged.
If display will not show, then timer battery needs to be recharged, or timer may be busted, or electric circuit is tripped off, or electric circuit heeds to be tested with circuit analyzer.
Set current time:
Press and hold CLOCK button.
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Release clock button.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Make sure lamp is turned on.
Make sure bulb is good.
Dec 11, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Woods model 16ULD/3A timer-lost instuctions
I have not heard of Woods 16ULD.
Woods timers sometimes have more than 1 model number for same timer, depending on who packaged and sold timer.
You posted under Woods plug-in timer with segments around edge of dial.
If this is not your timer, add a comment.
Also see lost of Woods timers where you might recognized photo of your model:
To program Woods timers with segments:
Rotate dial until current time lines up with arrowhead located on inner dial
Segments around outer edge of dial lift up.
Use fingernail, or small screwdriver to lift up segments when you want timer to turn OFF.
Leave segments down for times you want timer ON.
Slide switch located on top of timer is manual override.
Move switch to ON position when you want lights ON full time.
Move switch other direction for timer program to operate.
Timer dial rotates with passing time.
Program repeats each 24 hours.
Table lamp must be turned ON for timer to function.
If timer doesn't work, check receptacle for power, check that lamp is turned ON, and check that bulb is good.
Nov 30, 2010 | Coleman Cable Woods 59366 Lamp and...
I caNT SEEM TO PROGRAM OR CHANGE THE TIME . HOW DO I DO IT
Page showing Woods timers and models:
Add a comment with specific model number and I will help.
Instructions below are for Woods 59203 24-hour digital timer:
Plug timer in until battery is recharged.
If display will not show, then timer battery is dead and needs to be recharged, or timer may be broken.
Set current time:
Program timer:
Nov 27, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Hardware & Accessories Logo
191 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
