Question about Janome Sewing Machines
I can't get the tension right on my Janome DKS30 sewing machine. I can operate a machine but I am quite a novice. My machine is 9 months old and I have used it less than 20 times. Can you please help?
The stitches underneath the fabric look ok but the top stitches look like the thread has not gone through the fabric to join the bottom thread so the bottom thread is just a tiny loop on the top of the fabric with the top thread running through. Sorry if it's a jumble but I don't know how to explain it better. Thank you, June.
  • Janome Master
  • 11,732 Answers
Generally, if the thread issue appears on the top of the fabric, it is the result of a bobbin thread problem. In your case, it is probably something to do with the bobbin tension or threading. Remove the bobbin from the bobbin case. Make sure the thread is would smoothly on the bobbin. Check that when the bobbin is installed in the bobbin case that is turning the correct direction (consult your owner's manual). The bobbin turning the wrong direction will affect the tension. Also, verify that you are threading the thread through the bobbin case tension spring properly.
Further, if the upper thread is pulling the bobbin thread to the top of the fabric, the upper tension is too tight. The factory standard is usually the midway point between high & low number.
Since your machine is relatively new, it is probably still covered under warranty. You can have a Janome dealer check it for you. New machines sometimes are defective.
The following sites may be helpful. Keep in mind that adjusting the bobbin tension screw is a last-ditch effort, as tiny adjustments can make a huge change. It is easy to get it further out of adjustment. Be sure to mark the original screw slot position BEFORE making any changes so you can reverse them if things get worse.
http://www.superiorthreads.com/education/bobbin-tension-adjusted/
https://www.youtube.com/watch?v=TaH9yB7XUBk
http://www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all
Posted on Dec 31, 2016
    New Friend:
Sounds like your top tension is too tight. You may find it helpful to join a FaceBook sewing machines group to get further help. Happy Sewing!
Posted on Dec 30, 2016
  • June Baker
    June Baker Dec 31, 2016
    Thank you Rochelle. Your tips have been very useful, particularly the links to other sites. June.
My janome mylock 644d threads are continually breaking, have threaded the machine correctly, will sew for a few centimetres and then thread breaks. Any suggestions?
If you have not already done so, try changing your needles. Sometimes the needles will be slightly bent or dull and cause thread breaks. If this does not help check your tensions. These should be set somewhere between 4 and 6 generally. If one is far out of this range, try resetting it. If you try both these things and still have trouble, it is likely that your machine is out of time. In this situation it would be best to take your machine to a reputable sewing machine repair shop for repair. Retiming a serger can be very difficult for a novice, and can be quite and unpleasant and tedious job, best left to a professional who is well versed in serger repair.
May 01, 2014 | Janome MyLock 644D
I cannot get the tension to hold the thread.
ensure the presser foot is fully down before the machine is threaded
Mar 07, 2014 | Janome DC3050 Computerized Sewing Machine
Upper thread tension too loose even when I dial it up to 9
I suggest that you get in touch with http://www.janome.co.uk/index.php?option=com_chronocontact&Itemid=14 and have a chat with them ...
Mar 19, 2013 | Janome Magnolia 7330 Sewing Machine
Adjusting tension on overlocker
overlockers and sergers are annoying in that every time you change materials and threads they must be re-tensioned.
Get a scrap piece of material. Thread your machine correctly according to the instructions in your manual. If no manual most sergers are threaded, upper looper, lower looper then needles from right to left. Make sure you thread with the presser foot UP.
You want to balance the stitches Begin by adjusting the looper dials, you want them to meet right at the cut edge. Then adjust your needles. Keep doing test seams until you have them balanced. If you are a novice... try threading with each thread point having it's own color. That will help you identify which thread is giving you fits.
Have fun.
Oct 15, 2012 | Janome MyLock 634D Mechanical Sewing...
The tension on my montgomery sewing machine is too tight. After it has been adjusted it sews correctly for a few stitches and then tightens back up.
Seems to me these machines were made in Japan and branded by MW... Do some research and see if you can find out who made those machines. Then see if you can get a part direct from the original manufacturer. Seems like it was Janome (or who ever it was before "janome") Good luck.
Aug 02, 2012 | Montgomery Ward Sewing Machines
I have an old Janome Mystyle 30, which is still sewing like a dream, but in the middle of a project, I suddenly can't get the stitch tension right. Of course I can't find the manual either.
Unfortunately Janome don't provide links to their user manuals, so the only option is to buy one. I cannot find any free examples elsewhere, but this supplier has what you need at a reasonable price. If you find that you cannot eventually get the tension correct, then your machine is worn or out of adjustment and will need servicing. A smooth running machine is vital for consistent tension, so make sure that you have cleaned out the lint from the mechanism and applied sewing machine oil as advised in the owners manual.
Hope that I've been of some assistance and that you quickly solve your tension teaser! Please take a moment to rate my reply.
Sep 17, 2010 | Janome 4052LX Mechanical Sewing Machine
Janome left needle thread breaking CONSTANTLY
Sounds like a tension problem. Your machine should have two tension adjusters. One for each needle. The book that came with your machine will tell you how. Another possibility is a bent needle.
Feb 27, 2009 | Janome MyLock 634D Mechanical Sewing...
Noise from bobbin case on new Janome 4020
Check the bobbin to be sure it is inserted correctly. When you pull on the bobbin thread the bobbin should turn to the left(orcounterclockwise). If it doesn't, the thread will come out of the bobbin tension and give you loose stitches on top of the fabric. It will also make a noise because the bobbin is bouncing up and down.you will need to readjust your tension again.
sewman7
Dec 22, 2008 | Janome Memory Craft 9000 Computerized...
Janome Sewing machine - spring fell off
Can you post a photo of this so we can ident the actual spring and etc, if it is the check spring, it certainly will affect thread tension.
Post to here or via
www.bargainbox.com.au and I'll see what we can do to help if it is not too late so many months after the original plea.
Oct 02, 2007 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
305 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
