SOURCE: Toro Recycler 6.5HP recoil start cord pulls hard & snaps back in
This sounds like you have bent the shaft. This happens when you run over something hard. Hope this will help.
SOURCE: AUTORUN.EXE & RECYCLE VIRUS
Hi Ketan,
The problem seems to be in your machine rather than the pendrive.
Scan your machine for virus / Malware
Use Free Symantec...
ftp://ftp.symantec.com/misc/tools/nss/NortonSecurityScan.exe
and MalwareBytes antimalware..
To format ur pendrive:
Start > run > diskmgmt.msc
Right clcik on ur pendrive's partiotion and choose format.
SOURCE: JVC AV-K21T: TV goes off by itself
U know how to solder right?Take the backcover off take back of the handle screw driver taps where the part said it flickker or video back on, resolder that.
SOURCE: Menu window is blank on hp laserjet p3005dn. No
This seems like a bad formatter board problem. There has been a known issue with the formatter board for this printer. You may want to make sure if you are covered under warrenty. You could also try reseating all the connections on the board. Its located behind the right hand side cover.
SOURCE: toro recycler self propelled 6.5hp, 22" (gts)
Hi steve16092...
You may have MAJOR damage to your motor because of overfilling the oil.
Sometimes you can bend or break a piston rod when the engine is overfilled.
Meanwhile you can check a few other things.
Take your plug out and ground it against the head of the engine with the spark wire attached to it.
You should get a bright blue spark, if not then check your ignition module, it may be faulty.
If you have spark, then try putting a little bit of lighter fluid/or gasoline in the cylinder and reinstall the plug and try to crank it...if it cranks, then you may need to clean/rebuild your carburetor.
Please take time to rate me
