Question about Sewing Machines
My bobbin on my mb4 will not come out - Sewing Machines
My janome mb4 is 3 days out of the shop. I was able to stitch 2 letters and now all it does is birdnesting to the point that I have ruined 5 samples. I have changed needles, thread and bobbin
Verify that you are threading it correctly. Thread nesting will happen often because the thread path is not correct.
Since you just had it serviced, don't hesitate to take it back. Perhaps something was missed.
Aug 14, 2016 | Janome Sewing Machines
The tension will not stay set . It sews great and then suddenly starts looping!! Like carpet!!and no bobbin shows through on back side at all help!!!
Ewww! Wondering if the tension mechanism has gone haywire.
First, change the needle. (Is the thread still in the correct path or has it "jumped" out of place? If so, try slowing down the machine.) Remove the thread. RAISE the presser foot to insure the thread seats properly in the tension disk and rethread from the beginning. Check that the bobbin is threaded properly. Check the tension setting and retest.
If it is still malfunctioning, it may need service.
Mar 09, 2016 | Janome MB4 Four Needle Embroidery Machine
The machine is locked up. I've tried checking for thread behind the bobbin case, but cannot get the bobbin case to move.
Check your owner's manual troubleshooting section.
Assuming the machine is jammed with thread:
Try removing all the thread, remove the needle, the presser foot and the needleplate (if it is removable). If there is a thread tangle in the bobbin area, try to snip the thread loops and gently pull with tweezers or needlenose pliers. The best thing would be to get the bobbin case out of the machine. Once the bobbin case is out, the thread should be pretty easy to remove.
Oct 22, 2015 | Janome MB4 Four Needle Embroidery Machine
Tengo problemas con maquina de bordar janome mb4, me distorciona el bordado. I have problems with mb4 janome embroidery machine, embroidery distorts.
If your embroidery is distorted be sure you are using the right stabilizer for the fabric you are doing the embroidery on and enough for the density of the design.
I hope that helps.
Dec 04, 2014 | Janome MB4 Four Needle Embroidery Machine
How do I fix my MB4 that has locked after thread caught around bobbin. There must still be hidden thread, how can I fix please, regards Pam
IF THE GEARS ARE PLASTIC, THE LOCKING MAY HAVE CAUSED THE GEARS TO JUMP A TOOTH AND THREW THE TIMING OF THE MACHINE OFF. IT MAY NEED TO BE SERVICED.
Nov 20, 2014 | Janome MB4 Four Needle Embroidery Machine
Janome mb4
I suggest you call a Janome dealer and ask them your question.
Sep 02, 2014 | Janome MB4 Four Needle Embroidery Machine
Janome mb4
are you using a good thread and the same thread on the top and in the bobbin, different threads will sometimes act up. I also can not sew one brand of thread on my machine, try Mettler or gutermann's you can get them at JoAnn's or Fabricland. hope it helps good luck K
Sep 23, 2017 | Janome MB4 Four Needle Embroidery Machine
Janome mb4 why does thread ravel whiles embroidery a project
check for burrs on the needle plate and in the bobbin area
also check for burrs in the threading area,like one of the thread guides
Oct 15, 2013 | Janome Sewing Machines
What size are the bobbins for the memory craft 8000? I've compared the class 15 to my original bobbin but the class 15 has a ridge that my original doesn't have...the class 15J is more like the...
You need a bobbin like this:
You can puchase them from this link
http://www.sewingpartsonline.com/bobbins-janome-kenmore-elna-102261103.aspx
Janome have one standard plastic bobbin that fits almost all their models except
1600P, 1600P-DB, 1600P-DBX and MB4.
So if you see packets of plastic "Janome" bobbins for sale they will be the right ones.
Oct 08, 2011 | Janome Memory Craft 9000 Computerized...
I have a Janome MB4 and have had so many problems with the tension. I use the same top thread and the same bobbin thread. Every once in a while, it sews perfect. Other times I have so many loops on the top...
Hi!
I was having the same problem(s) and I loosened the tension on the bobbin case and switched to prewound paper bobbins and everything sews beautifully.
Hope that helps!
-Donna Jo
Apr 10, 2009 | Janome Sewing Machines
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
