Question about Vanguard Heating & Cooling
What is causing my eyes and nose to burn?
I have a Vanguard three burner infrared floor model heater. This year I blew it out with the CleanSafe Dust Remover Canned air as I usually do. After a while with heater on, and being in the room, my eyes and nose start burning. Never has happened before.
  • 319 Answers
SOURCE: shuts off after slowe burning ,8888 flashes, and all burner lights fash. Monitor 441 oil heater.
Have you looked at, and or followed the troubleshooting suggestions at this website?
There is a full troubleshooting guide for your model. Let me know if you have checked this site out, then give me more details as to any other indications.
How old is this unit, how long has it been plugged in to the current electric outlet, etc.
Posted on Jan 19, 2008
  • 9 Answers
SOURCE: Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Posted on Mar 22, 2009
SOURCE: flame burns to high
I had this problem. From using the center brick most of the time, lots of dust bunnies build up in the gas chimney behind the brick.
Tie 2 pipe cleaners together with a small perpendicular circle at the top and carefully remove the dust bit by bit by twirling the cleaner.
The brick should fire like new if it is carefully cleaned out.
Posted on Dec 14, 2009
  • 274 Answers
SOURCE: My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Posted on Jan 10, 2010
  • 3150 Answers
SOURCE: Vanguard wall heater does not burn correctly
Hi the plates/burner needs cleaning out blowing then out with air line when off should help
Posted on Jan 26, 2010
Why is the right side of the heater flame higher and hotter then the left side
Combustion needs air mix in the correct proportion to burn efficiently-also gas supply may be stronger on the outlet side of burner causing an imbalance-chech for obstruction in either area-cheers Denny
Oct 11, 2013 | Vanguard International Blue Flame - Large...
Our 15 yr old propane Vanguard heater was put into use 3 days ago, and has worked properly. Today it lit up after starting the pilot light this am and we left it on about three hours. We turnd it off...
If the heater has been cleaned annual or before you put it back in service this season, the Oxygen Depletion Sensor ODS) may be clogged with dust, lint and/or pet hair. So the sensor is reading it as not enough oxygen in the room for safe operation. Also, the Thermocouple may be loose where it screws into the control valve. In either case, you can solve the problem yourself, if you feel comfortable with dismantling the heater cabinet to get to all the inner workings?
Hopefully, after 15 years, you still have your Owners Manual, which can walk you through dismantling the heater. If you don't have it go to find the Model Number of your heater and you can download & print it. Also, it will tell what and how to clean it. I highly recommed that you have a vacuum cleaner (a shop vac works well) that has a hose and brush attachment and some canned compressed air with a straw nozzle (like you clean your computer with) to help expedite the cleaning process.
if you have any further questions concerning the cleaning, feel free to email me at
Feb 11, 2011 | Vanguard International Infra Red - Medium...
Jan 26, 2010 | Vanguard International Infra Red - Medium...
I have a vanguard propane wall heater, 5 burners Model#vp2600c that the two middle burners flame goes above the burners and now has started to burn through at the top, what all parts do i need to replace?
The burner and anything else that was damaged. You might want to get the advice of a local professional. Remember, this thing runs INSIDE your home, where you live, eat and sleep. You want it to be safe, my friend.
Thanks for your question at
Jan 06, 2010 | Vanguard International Blue Flame - Medium...
2600c burners shoot flame too high
The holes in the burner or the burner itsef could burst at the seam have you checked that? Dust in the grates can cause it too have you blown it out?
Jan 02, 2010 | Vanguard International Infra Red - Large...
I turned my propane fireplace on and it set my smoke alarm off. We have lived here for three years and never had this problem before. Please advise.
check to see if the flame is pure blue. if not you have incomplete combustion letting CO or CO2 into the room. The flame will look yellow if this is the case. An orange flame indicates dust and dirt around the burner assembly. If it is yellow, the should be 1-2 set screws on the back of the burner assembly that will let you adjust the primary air being mixed with the propane.Adjust until you get blue flame and tighten set screws.
Dec 05, 2009 | Vanguard International Blue Flame - Large...
I have reddy pro 100 lp gas heater when i run it within afew minuets my eyes nose and throat burn. ia'm using a 20#cylinder the flame is pretty much blue
are you using it in a closed room? you should be using it where there is air circulation. what's happening is the heater is using up oxygen and is producing carbon monoxide which is poisonous and if you are not careful IT WILL KILL YOU!
Oct 25, 2009 | Reddy Heater RLP100 Portable Forced Air...
Burner keeps going out
It might be the ODS Pilot Assembly. It could be clogged with dust or lint.
It might be low gas pressure.
It could also be the pressure regulator.
Oct 07, 2009 | Vanguard International Infra Red - Large...
Heating & Cooling Logo
29 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
