Question about Winter Sports
How to change brakes on 1994 ski doo formulat stx bombardier 583
  • 85 Answers
SOURCE: I have a Ski doo 583 RAVE motor theat backfires
It sounds like you have a reed problem they should be in a "cage" just behind the carbs on the cylinder and if they were missing a piece or if they were cracked it would cause the engine to backfire. If they are in good condition they should close against the cage and stop the back pressure coming through the carbs.
Posted on Jan 21, 2010
  • 5 Answers
SOURCE: I have 95 Ski-doo formula z 583 and last weekend i
check the fuses?if not then there must be a burnt wire someplace close to the exhaust manafold ,either that or your selonoid is burnt out.
Posted on Mar 11, 2010
heimlich
  • 1978 Answers
SOURCE: i need to know the head bolt tourqe for a 1980 tnt ski doo
18 - 22 ft/lb
Posted on Aug 23, 2010
  • 747 Answers
SOURCE: Sea doo Bombardier jet ski, engine has no spark
fuses coil ign control center computer
Posted on Jun 28, 2012
Hobbit_who
  • 2044 Answers
SOURCE: how do I adjust the oil mixture on my 1997 ski doo 583 grand touring snowmobile
The Oil Injection runs off a Pump on the Bottom of the engine and if I remember correctly... There is a Cable that runs off the Throttle and you can adjust it there. I have always been a fan of adding Oil to the Fuel Directly. I have replaced way too many engines due to Oil Starvation so as an added precaution, I still pre-mix my Fuel/Oil but the Ratio is not a complete 40-50/1. More like a 100-125/1. Do I ever foul out a plug? I DO... have I ever Oil Starved an Engine... NEVER... 2 Spark Plugs last me an entire season but I replace them at the Beginning of the season.... I would STRONGLY RECOMMEND cleaning the Hose that comes from the tank....
Posted on Feb 07, 2015
Why is my 1997 ski doo 583 grand touring is dumping to much oil into the gass when running. it smokes badly and spits and sputters when you give it gass. what is it?
Time to rebuild most likely cooked internals but its easy just take your time disassembling to remember the assembly and a friend at a machine shop helps or a hone or equivalent
Feb 07, 2015 | Winter Sports
Why does my 1995 seadoo bombardier shut completely down while wide open
Very likely a cracked wire on the ignition-advance. As the throttle is advanced so is an advance-lever that causes the wiring attached to it to Flex, causing an intermittant loss of current to the coil/CDI.
The flywheel may have to be removed to repair/replace the wiring.
Aug 16, 2014 | Tempest SeaDoo/Sea-Doo/Bombardier Jet Ski...
2002 gti sea doo wont turn over on the first try
if you have one of the kill cords that is round and it snaps onto a round button that has a silver dot in the center that when the kill lanyard is snapped into place makes a connection to the silver part inside of the kill lanyard itself. most the time its because it is still verifying that it is the right key. they are programed to match you CDI box/ignition module of your ski. this prevents theft. if you clean both the key and the button the key connects to with some rubbing alcohol to insure a good clean connection will most likely solve the problem. when you put the key on the ski you should hear a beep then wait 5 to 10 seconds before hitting the start stop button . that gives the ski time to recognize the key is in fact the correct key to the ski.. hope this helps
Jul 25, 2012 | New Ray 112 Scale Bombardier Sea-Doo XP...
See doo wont start
It should start on land more easily than in the water (no drag on impeller). However, you should not run your boat for more than 10 or 15 seconds dry or you might damage the motor (too much heat build up). If you put a flush kit on your boat you can run it as long as you want in your drive way. We always start are boats on the trailer for a few seconds before launching. It makes the first in the water start a lot easier.
Apr 02, 2010 | Encore Software Kawasaki Jet Ski...
I have 95 Ski-doo formula z 583 and last weekend i lost my lights and all gauges and reverse beeper. any ideas what could be problem
Mar 07, 2010 | Simon & Schuster Ski-Doo: X-Team Racing...
Jan 21, 2010 | Sport & Outdoor - Others
Winter Sports Logo
94 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
