Question about Comfort Glow Heating & Cooling
Comfort glow cbt30pt will light when you turn it to heat the pilot dies down and after about 30 seconds it all cuts off. replaced thermo and lower regulator did the same before replacing parts
SOURCE: Comfort Glow Vent-free Gas Heater CGN18B
Check with Ebay seller s.a.w.inc for available thermocouples. If that doesn't solve the problem the valve unit will likely need replaced.
Posted on Feb 13, 2009
  • 74 Answers
SOURCE: pilot light is lit fires up for 30 seconds then shuts down.
do you have a CO detectors? If so try resetting them
Posted on Feb 22, 2010
mxc2
  • 146 Answers
SOURCE: comfort glow mod. cbt30pt lp
It sounds like you are loosing connection with your thermocouple to the gas valve.
Here are som einstructions on reseating the thermocouple.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
Posted on Oct 13, 2010
  • 1015 Answers
SOURCE: Have a GTI Insert Replaced
It sounds to me like you have a bad flame sensor.Luckily most of the time they are pretty easy to change. If you have your manual it will show you the physical location of flame sensor. Usually 1 or 2 screws holding it in place. Remove screws and unplug wires to remove sensor.Install new sensor and hopefully you're in business. Thank you.
Posted on Nov 22, 2010
TheMobilian
  • 8220 Answers
SOURCE: Tempstar GNK074N14A3 furnace that won't
Blow the cobwebs out the exhaust fan tubing to the control can get verification of ignition
Sequence:
Posted on Sep 21, 2011
Tip
Gas Hot Water Tank Not Producing Hot Water Pilot will not stay lit Trying to...
Trying to light your pilot light and it keeps going out when you turn on you gas valve. This is a common problem when your thermo-couple goes out. The thermo-couple sends a small electrical charge to the gas valve to keep its self lit. When the unit calls for heat the pilot flame gets bigger producing more electric and tells the gas valve to open the main gas valve to the burner tubes. The thermo-couple is an easy item to change most of the time. You will need to follow these steps to change out your thermo-couple:
1. Turn off the gas (there is an inline shut off on the supply line before it reaches the gas valve, you need to turn this crossways to the pipe)
2. Locate the thermo-couple it will look like this and be attached to the gas valve
3. Unscrew the thermo-couple from the gas valve
4. Remove the other end of the thermo-couple from the pilot holder
5. Measure or take the old thermo-couple to the hardware or appliance store with you to get the proper length (there are many different lengths of thermo-couples)
6. Reinstall the bulb end at the pilot
7. Reinstall the threaded end on the Gas Valve (make sure not to cross thread the thermo-couple it should start by hand)
8. Turn the gas valve to the pilot position and hold down the red button wait a few seconds then turn off and do again (you will need to do this around 5 times in order to get the gas back up to the pilot light then try and light the pilot)
9. Try to ignite the pilot light.
10. Once you get the pilot light lit you will want to hold down the button for 60 seconds then turn the gas valve to the on position.
Here is an image of a thermo-couple (they will all look similar to this):
Thank you for choosing FixYa.com. If you have any further questions please post them and we will gladly answer them
Justin
on May 03, 2011 | Plumbing
My water heater pilot light won't stay lit
I would try cleaning the thermo couple surfaces with some steel wool... Both where the flame contacts the sensor, and the electrical contacts. Even a small increase in voltage may be enough to hold the pilot valve open. Both black, and white soot on the sensor end, can act as an temperature insulator, lowering the output voltage.
As for finding the part numbers for replacement: http://www.reliancewaterheaters.com/media/48391/242117_RPPCR01111-Reliance-Parts-Catalog.pdf
Feb 17, 2016 | Water Water Heaters
I have a 30000 btu rinnai floor heater mod 630530. The pilot wont stay lit . I have installed a new thermo couple . please help
be sure the thermocouple is in the pilot's flame and hold down the pilot lighting button long enough to heat it before trying to operate the heater...20 to 30 seconds should be enough. If this doesn't work, you may have a bad gas valve
Feb 21, 2015 | Rinnai Heating & Cooling
How do you relight the gas stove.
not knowing the year ,, there are 2 ways stoves light, pilot light and glow plugs, following the gas line into the oven itself, If it has a pilot light you will see the control for it,, just hold a match or flame to the end of it and you should see a button to push,, If you have a glow plug,, it should light after a few second of turning on the knob,, watch to see if there is a glow next to the oven burner if there is and its not lighting,, your thermo coupling may be bad
May 30, 2011 | Frigidaire Gallery 30" Self-Cleaning...
I can't find an instruction manual for a Sunvic 307 xls online
This is simple to light. Turn the selector switch to pilot and push it down then push the striker button and watch it light. Hold for 30 seconds and then let off. Turn the selector switch to the desired comfort level and it will work.
Jan 24, 2011 | Desa International CBN30T Central Heating...
Comfort glow mod. cbt30pt lp gas valve closes off after ten seconds on
Oct 11, 2010 | Desa International CBP20T Wall Mounted...
Pilot won't light
You may have to bleed some more air out of the system.
Your ODS pilot may be clogged with dust or lint and needs to be blown out with air(less than 30 psi).
Your regulator or gas valve may be faulty.
Dec 09, 2009 | Desa International Comfort Glow Infrared...
I have a Comfort Glow propane heater connected a 20lb tank. The pilot has a hard time staying lite but when I do get it lite ang turn the hearter on low it will shut off in a minute or in some cases 20...
If you have a pilot, you have a thermocouple. I would start with the thermocouple. The thermocouple is supposed to be heated by the piolet and to keep the pilot gas on. If it is faulty, the pilot will quit and the heater will not reignite until you light it again. Good luck...Lee
Sep 21, 2009 | Desa International Comfort Glow Infrared...
I have a comfort glow gas heater that the pilot lights and when I start the heater it works for about 30 seconds then the whole thing shuts down.
Jan 02, 2009 | Heating & Cooling
Heating & Cooling Logo
46 people viewed this question
Top Comfort Glow Heating & Cooling Experts
Vernon Taylor
richie46
Are you a Comfort Glow Heating and Cooling Expert? Answer questions, earn points and help others
