Question about Clymer Marine Maintenance and Repair Manual '99 '02 Yamaha 115 250 HP 2 stroke Outboards
2003 yamaha 250 hpdi no spark on #3 #2 with engine running but has spark when cranking
2003 Yamaha outboard HPDI will start but will not
Many possibilities. Mine had been sitting. Old fuel in HP fuel pump reservoir was clogging HP pump. I was able to disassemble, soak and clear pump and get running. New pumps, big money. My boat, twin 150 HP HPDI
Sep 23, 2014 | Boating
2003 Yamaha YZ 250 F will not start after power washing
Hi, Jordan moisture, condensation, rain, or bike washing can make the bike run sluggish, not able to rev, and misfire. Older bikes, engine configuration, and exposed electrical components are at the front of the line for acting up. During the diagnostic procedure spray Electrical Contact Cleaner on corroded wire connectors/pins/sockets etc. and apply a liberal amount of "DIELECTRIC" grease to the mating harness/wire connectors. WD40 works great for eliminating suspect areas in your quest to find the real offending gremlin.
For additional insurance you can spray a High Temp Clear Coat on the most vulnerable areas it will work like Scotch Guard does on fabric. Fabricate a rubber or plastic splash guard to deflect water coming off the front wheel getting to the front cylinder spark plugs. The design should be adequate for its purpose with the least amount of airflow restriction to cool the cylinders. The usual suspects are:
1. Air filter soaked with water.
2. Water in the fuel system gas tank and carburetors.
3. Wet ignition coil packs.
4. Spark plug boots wore out or loose allowing water to enter.
5. Spark plug cables old and cracked check for spark leakage in the dark.
6. Spark plug wells filled up and drain holes clogged.
7. Water in a wire harness that has exposed open ends and have a sharp bend or crimp allowing the liquid to form its own pool of potential threats to chaffed wiring.
8. Sensitive fuel tuners and downloaded ECM remaps may get confused with the abnormal cylinder temperature difference in a V-4 engine configuration.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
YZ250F starting trouble after washing
No engine start after pressure wash
Yamaha YZ250FR Owner Service Manual
2003 Yamaha YZ250F Owner Manual
Oct 28, 2017 | 2003 Yamaha YZ 250 F
2002 Yamaha WR250 Keeps fouling the spark plug. What are the possibilities and things to check? Thank you!
Hi, Lynnmcneely and the usual suspects are:
1. Fuel mixture too rich or enrichner left out too long.
2. Faulty spark plug.
3. Incorrect spark plug for the engine type or service.
4. Piston rings badly worn or broken.
5. Valve guides are badly worn and/or seals worn, crushed or have come off the valve guide and are pumping oil through it.
6. Spark plug cable weak or leaking check for spark jump in the dark.
7. Faulty ignition coil.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Why Does My Dirt Bike Keep Fouling Spark Plugs
YZ250F fouls plugs
YAMAHA WR250F Owner Service Manual
OEM parts for Yamaha
YAMAHA WR250R Owner Manual
Sep 29, 2010 | 2003 Yamaha WR 250 F
Need to change crank case and engine oil in my tri Z 250 . is it the same as a dirt bike
hello, i have a 350 warrior, my oil filter is right beside gear shift side on case, i think it has 3 screws, its a small cover
Mar 30, 2010 | 2003 Yamaha YZ 250
Beeping sound when starter is turning over for the
Have u replaced the spark plugs? Is this the beeping noise you hear when you first turn your key over the same as past times you have started the motor? It just keeps going though right? I would make sure you have the right level of fluids and make sure your fuel pump works, fuel filter isn't clogged and plugs and wires are in good shape.
If that is all good then you might have a bad coil pack. Test it and make sure you are getting correct voltages, if not then replace it.
Also did you winterize your motor after the last time you used it? If not you could of cause some internal damage to the motor.
Good Luck,
Mar 04, 2010 | Boating
Quad keeps goin through spark plugs
The engine is running 'rich' thus fouling the spark-plugs, you will have to set the air-mixture ratio.
Jul 26, 2009 | 2003 Yamaha YZ 250
Not starting and metalfileing in oil filtter
Something is really wrong.Your gears engage correctly? plug on the spark plug's cap a new spark plug and ground it on the engine and crank it to see if there is any spark.If it is then check your carb.
Jun 13, 2009 | 2003 Yamaha YZ 250 F
250 cc yamaha serial # 25y-000165 what year and model tech?
1983-1985 Yamaha IT250K.
You need several things to get it to start: A clean carbuerator, a good reed cage, a good, clean spark plug, and compression.
Start by pulling the spark plug. If it's oily/dirty, replace it. Then kick the engine over, and you should get the motor to turn over really easy. Place the plug back into the hole, and the effort to turn the engine over should be hard, if there is compression. If there is no compression, you need to remove the cylinder head to find out why. It could be a hole in the piston, bad rings, or worse, bad crank seals. If the piston looks okay, then chances are the problem lies in the Mikuni carbuerator. It's an simple device, but you need to make sure the needle seals the bowl when the float level is correct. You also need to make sure your air enrichment circuits are free of dirt and varnish. Give it a good scrubbing. Once the carb is clean, and the float level is sound, make sure to check the air filter to ensure it is clean. The carb ensures fuel is correct. Lastly, there is spark. Your plug wire shouldn't have any cracks, and when you crank it over, there should be a spark from the plug. There is a remote chance that the pickup coil has burned out, but the ignition system on these old Yamahas is pretty reliable, so look there last of all.
Apr 13, 2009 | 2003 Yamaha YZ 250
Won't idle steadily
Check the rubber boot that joins the carby to the engine to often have seen the hose clamps over tightened therefore creating a split in the rubber letting to much air in giving the rough idle eventually you wont be able to start it at all (have a good thorough look inside an outside of boot doesnt take much)
Nov 12, 2008 | 2003 Yamaha YZ 250
Clymer Marine Maintenance and Repair Manual '99 '02 Yamaha 115 250 HP 2 stroke Outboards Logo
81 people viewed this question
Top Clymer Boating Experts
Fabrice Wolters
Colin Stickland
Colin Stickland
Are you a Clymer Boating Expert? Answer questions, earn points and help others
