The timer light is flashing slowly after it turns itself off
    Top Expert:
  • Televison & ... Master
  • 75,017 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. If blinks continue without any pause, the main board is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result will display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Dec 30, 2016
Testimonial: "Thank you there is one blink with long pause between before again is that one or do I count total blinks."
  • Christine Meiers
    Christine Meiers Dec 30, 2016
    Sorry this is for an air con not a television.
Fan stops then operation light flashes rapidly and timer light comes on flashing slowly. Turn off with remote and the lights continue to flash.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 22, 2015 | Televison & Video
Hi there I have an r410a and the timer is flashing continuously if I turn the unit off outside ie reset it then it comes on for a few minutes then shuts down can you help please
brand and model number would help here. Flashy lights usually mean error codes. count the flashes or if it is flashing fast or slowly.
Jan 04, 2015 | Heating & Cooling
Sony grand wega keeps turning itself off
Try to restore settings to default, if not try upgrading the software...... but iam pretty sure it is ur sleep timer ;)
Feb 05, 2014 | Televison & Video
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Thinking of getting the TI150 3-in-1 Timer - Can it set to repeat a countdown over and over?
Review at Amazon seems to say the timer can repeat the same countdown each time button is pushed and countdown is activated.
Amazon review says:
The timer is easy to set. You just set the time, then hit the big "start/stop" button and the little "H" and "M" on either side of the timer display flashes.
To clear the timer, just hit both the "h" and the "m" buttons simultaneously. (so time has to be cleared)
To stop the alarm or to turn off the timer before the alarm sounds just hit the "start/stop" button.
On the back of the timer, there are 4 different on/off switches: flashing light alarm, sound alarm, vibrating alarm, and one for hours/minutes or minutes/seconds.
When I set the timer on my desk, it moved around when the alarm went off but when I turned off the vibrating function, the timer didn't move around.
If you need to turn off both the sound and vibrating alarms and use only the flashing light alarm, the light is quite noticeable by itself if placed nearby in your line of sight (within a foot or so). This would be very handy if you're near a sleeping baby! :) But if you clip it on a breast pocket, I would use both the flashing light and vibrating alarms. The vibrating alarm does make a sound, but it's not as loud as the ringing alarm.
Dec 27, 2010 | General Tools Hardware & Accessories
On/off green light flashes. Picture comes on for
the timer is set for a short time, try to get to the menu quick and turn off the timer it may take several tries.
Mar 06, 2010 | Televison & Video
Tv won't turn on or respond
if its a sony bravio LCD the backlight inverter failed
Dec 06, 2008 | Televison & Video
Green light flashes 3 times will not operate
Its may be the thermistor is defective or out of range or the board itself, the unit will not operate unless the defective part is not replace.
Mar 04, 2008 | Fujitsu 18C1 Air Conditioner
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Televison & Video Logo
Top Televison & Video Experts
