Question about Westinghouse Televison & Video
Westinghouse UW40T3PW Screen. Wondering if it's the panel, t-con board or ribbon connector? I don't have the remote for a factory reset but I don't think that'd help. Any suggestions appreciated!
    Top Expert:
  • Westinghouse Master
  • 74,666 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Dec 30, 2016
westytech
  • 120 Answers
SOURCE: Westinghouse lvm-47w1 picture goes dim
Hello, I can tell you from experience that this is an inverter issue. Both the master and the slave have several transformers and sometimes you can't tell if they are damaged or not. I would recommend testing the leads from the inverters to make sure which one of the two is the one causing the dim picture.
Posted on Apr 15, 2010
SOURCE: verical lines on half of the screen
I have the same prob. Please help my *** out here!
Posted on Jun 15, 2010
SOURCE: sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
Posted on May 11, 2012
gopakumarg43
  • 74666 Answers
SOURCE: LVDS flat ribbon cable. full description needed
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on May 02, 2014
gopakumarg43
  • 74666 Answers
SOURCE: Westinghouse VR-4090 Issue double image on screen. I disconnect the right ribbon from T-Con to LCD go's away. Bad T-Con board?
Possibility. Replace the same and check. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Aug 26, 2015
Wondering if its my main board on my hdtv flat screen. it comes on normal for about 10 to 15 seconds then i lose video but not audio
sounds like a failing t-con board. this board is on the back of the screen controls the signals to the screen. ribbon from main board goes to the t-con board.
Jan 28, 2017 | Westinghouse Televison & Video
How do I reset my tv or set it up
Westinghouse 40 Lcd Manual - Heroku
gfdc.herokuapp.com/Westinghouse-40-Lcd-Manual.doc
Westinghouse 40 Lcd Manual - gfdc.herokuapp.com ... led 1080p hdtv - westinghouse 40 class 39 5 diag led 1080p hdtv black model dwm40f1y1 c ... lcd hdtv - buy westinghouse uw40t3pw 40 1080p 120hz lcd hdtv led lcd tvs amazon ... 1080p hdtv dvd combo user s manual vk 40f580d tv dvd combo pdf manual download, ...
Sep 17, 2016 | Westinghouse 40" Class LED 1080p HDTV...
Aug 26, 2015 | Westinghouse Televison & Video
May 02, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
How to fix upside down screen on led tv
Time control board or lcd panel itself. Some times you cannot get the t con board. it may only come with the LCD panel. Check Shop Jimmy website.
May 29, 2013 | Vizio E390-A1 39" 1080p 60Hz LED 2.95"...
WHY IS MY TV HAVE LINES WITH COLORS ON THE SCREEN
Could be several reasons, you could have a cracked screen, defective LCD panel, defective t-con board, bad ribbon connection and so forth. You will need to get a diagnoses performed on the set to be sure
Nov 27, 2012 | Westinghouse SK-32H590D Television
Programing codes for 40" uw40t3pw
I need the codes for my brighthouse cable remote. can anyone help?
Jul 03, 2012 | Westinghouse Televison & Video
Westinghouse sk-32h590d video problem audio very
Good day!!!!
That problem is commonly cause of faulty T-CON board try to check first the pico fuse on that board if open if have soldering skills try to replace it first..If you don't have soldering skills or replacing of fuse not help..try to replace the whole T-CON board..
Hope it helps..
Feb 11, 2012 | Westinghouse SK-32H590D Television
My 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Nov 18, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
29 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
