Question about Coffee Makers & Espresso Machines
DGB-650BC not brewing hot coffee, only warm. Machine is only 2 months old. What to do to fix?
SOURCE: Braun Flavor Select will not brew coffee.
I assume You are talking about the water-brewing heater thereare two, the second is the heater that warms the coffee pot (I think!). When the water-heater is encrusted with calcium deposits it "thinks" that the water reservoir is emptyand ceases the brew cycle. water boils at 212 degF and the heater will go to a much higher temperature. I will leave you with the same solution as was posted to another problem that may have similar cause:
corvette2
I have the same machine, Braun KF180 12 Cup Coffee Maker. In normal operation the brew cycle is stopped when the water reservoir is empty. The only way the coffee maker knows if that is true is when the water-brewing heater gets too hot. Your brewing heater is probably encrusted with calcium deposits if you have been heavily using the coffee maker. Vinegar will work but it is weak and you will have to cycle this solution through many many times. You should instead use "Lime Away" or "CLR" and let it sit there in a brew cycle or multiple brew cycles for a while. NOTE: Remove the filter when cleaning this way and when the brew cycle is complete, rinse thoroughly -- your taste buds will let you know if the machine is not rinsed thoroughly. -- Good Luck!!
Posted on Jan 26, 2009
  • 131 Answers
SOURCE: Warming tray too hot
You can either replace the warming element with a new one, or some people put 3 or 4 pennies on the top of the warmer tray. Don't laugh- this really does work!
Posted on Feb 12, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart DGB-650BC instruction manual
Here's a link to the manual:
http://www.cuisinart.com/share/man/1013_man.pdf
-Tha Mp3 Doctor
Posted on Mar 22, 2009
SOURCE: My DGB-500 Cuisinart Grind & Brew coffee maker leaks coffee
I found out that internally the water line that comes off of the heating element is made of a rubber/silicon material. The heating element is so hot that it scorches or dryrots the tube and it cracks causeing leaking. Sometimes it comes pouring out and other times it just is enough to make it a pain. I have taken the time to get my specialized screwdriver set and take off the bottom of the pot, but have not been able to find a replacement tube for it. (They also made the tube so that you dont have enough to cut the broken end off and put it back on and if you COULD do it, they also put an "X" in the original tube so if you cut it and try to put it on you cannot push it on far enough. Other than this, it was a great coffee brewer for me for the past four years. (Put baking soda and water paste on the coffee stain if you have formica counters. A few times of doing that and the stain will come clean)
Posted on Apr 13, 2009
SOURCE: delayed brewing
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
Posted on Jul 26, 2009
Cuisinart dgb-650
In an empty machine,(no coffee, no filter), pour in a 50-50 mixture of water and white vinegar. Allow the machine to start brewing and when a cup or so has run through, stop the brewing process and let it sit for an hour or two. This should dissolve some of calcium buildup in the machine and allow it to complete a full cycle. May have to do this a couple of times to fully clean out the mineral buildup. After cleaning, run a pot of clear water through to rinse out the remaining vinegar.
Dec 03, 2017 | Cuisinart Coffee Makers & Espresso...
Shuts off after brewing
THE COFFEE POT SHUTS OFF RIGHT AFTER ITS DONE BREWING AN THE COFFEE IS WARM NOT HOT !!! THE POT IS ONLY 10 OR 11 MONTHS OLD !!!
Nov 16, 2012 | Cuisinart DCC-1200 Coffee Maker
Disassembly instructions - will not grind
watch this video http://video.cuisinart.com/video/video.php?s=cuisinart&t=demo&f=Cuisinart-DGB-650BC-Automatic-Coffeemaker its from cuisinart.com this may give u the complete answers and instructions to your problem,,,thank you for using fixya.com
Feb 11, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Machine Brewing Water
Try an experiment - brew a test cup, but use only a small amount of grounds in the brew basket (use a paper filter) [or else, put the grounds in the gold tone filter basket]. See if the machine makes coffee (albeit weak coffee). If it does not make coffee, see if the water is draining properly from the brew basket, or if it is leaking over the sides of the brew basket. Also, make sure the lid to the brew basket is completely open and in the correct position.
If you still get water only in the caraffe, replace the brew basket. The part costs about $11.95 with shipping - or even call Cuisinart to see if your 3-year warranty will cover the issue.
-Tha Mp3 Doctor
Mar 03, 2009 | Cuisinart Thermal DGB-600 Grinder
I have a dgb600bc grind and brew. It will initially grind and brew the coffee hot, but as soon as the brewing is done the heating element shuts off causing the coffe to slowly get cold.
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
Hope this will help you.
/Mirran
Jul 24, 2008 | Cuisinart DGB-600 Coffee Maker
Does not brew a full pot anymore.
I had the exact same problem with my machine making 1 cup at a time.
Here is the solution:
1. make solution of 1 part vinegar & 2 parts water.
2. pour solution into resivoir and set for 2 hours
3. run solution through machine (yes, you will have to stand there and keep pushing the buttons).
4. take same solution (now very hot) and run it through machine 5 or 6 times
5. make fresh solution and continue process
Sep 01, 2007 | Cuisinart DGB-600 Coffee Maker
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
